02-22-2010, 05:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | hope we can see TE365 and other new lg in next update br keaelite |
The Following User Says Thank You to keaelite For This Useful Post: |
02-23-2010, 12:34 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,604 | Quote:
[X] ADDED CODE READING SUPPORT FOR FOLLOWING MODELS: GM310, GB250, GB255, GC900, GD900, GW520, GW525, TE36X/GT36X, GD510, GD510GO TE36X/GT36X=TE360, TE365, GT360, GT365. Clear ????? Br | |
The Following 4 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
02-24-2010, 00:51 | #4 (permalink) | |
Registered User Join Date: Nov 2002 Location: USA Age: 43
Member: 17846 Status: Offline Thanks Meter: 4 | Quote:
02-24-2010, 01:13 | #5 (permalink) |
Member: 17846 Status: Offline Thanks Meter: 4 | OKAY I WAS LEARNED THAT ITS AN INFINEON CHIP, SO I FOUND THE MODEL LISTED IN THE LG-INFINEON MODULE, NOW TRYING TO READ CODE, THIS IS WHAT IM GETTING: Press power on ! Starting communication ... Platform: E-Gold Lite ... Error ... ! Time needed - 00:00:00 I AM USING THE CABLE NUMBER: 014 |
02-25-2010, 17:38 | #8 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,604 | You need to use KE500 cable ! If you get phone detected as EGOLD Lite then cable pinout is bad so check it ! Also be sure latest version used. Also one succesfull log for TE365 can be seen here http://forum.gsmhosting.com/vbb/show...postcount=3004. Both Te36x/GT36x are oversee variants of KS360. So use KE500 cable and latest update and all must be fine ! Br |
02-25-2010, 22:14 | #9 (permalink) | |
02-25-2010, 22:31 | #11 (permalink) | |
Okay, Yes I was using the 014 cable, which is the KG800, and this explains what your are saying that the cable is wrong since its reading it as EGOLD, but the "047" KE500 cable is not connecting at all, when i connect and hit the power on button, it is says: ERROR..! Its a new cable though.. And im using the latest version. | |
02-25-2010, 22:40 | #12 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | Hi. Check Your cable. I've got inverted tx with rx. Good pinouts: keyboard top 1.........18 1: Gnd 2: Box Tx/Phone Rx (RJ45 pin-2) 3: Box Rx/Phone Tx (RJ45 pin-3) 5: Gnd 15: Gnd B.R. ProcyOne |
The Following User Says Thank You to ProcyOne For This Useful Post: |
03-15-2010, 18:51 | #13 (permalink) | |
Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 41111840 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 IT WAS THE CABLE, THANKS EVERYONE | |
TE365 and other new lg update where? | keaelite | FuriousGold | 2 | 02-09-2010 03:41 |
How we can Backup E200 and other smart phone | aukonline | HTC & Smartphones ( WM Without Touch) | 0 | 03-04-2009 17:38 |
plz add lg kg300 unlock and format ffs option in next update | rajabrotherscom | Infinity-Box | 1 | 05-08-2007 12:19 |
lg s5100 and other new lg cal. data | GSM_MARSHALS | Multi-Box | 2 | 05-01-2007 14:13 |
20-02-2007 We are always care about you. New LG flash files update 400mb! | GSMtricks | Multi-Box | 7 | 02-20-2007 12:44 |
