How to relock bootloader on Huawei FIG-L11 and ANE-L21 ? Hi, I have Huawei P Smart (FIG-L11) and P20 Lite (ANE-L21). How I can relock bootloader for these phones? Because they had the annoying message at startup: "The device had been unlocked and can't be trusted". Both phones are after successfully downgrading using Resurrector with TP and downgrade firmware. For FIG-L11 I flashed: FIG-Downgrade-Board-1048-8.0.0.fcff After I changed Model to FIG-L11, Vendor to hw, Country to eu with FlyCaptain. After I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector. For FIG-L11 I flashed these two files: Figo-L11_8.0.0.129(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XUW.cfs update_FIG-L11_8.0.0.129(C432)_hw_eu.cfs Then unlocked the phone and I have readed the bootloader code with FlyCaptain and in cmd got the message: C:\Users\adb>fastboot oem relock 3017477598189510 ... FAILED (remote: stat not match) finished. total time: -0.000s With Huawei P20 Lite I have the same problem. WHY I CAN'T RELOCK BOOTLOADER?? PLEASE HELP ME TO RELOCK BOOTLOADER!!! |
Same message at startup, same problem here...... |
.:hack3r2k:. or other product manager, please help us!!! |
Seems the code is wrong. Can you try reading again ? Also post a full detect log. Also can be from incompatible fw . Did you set correct model vendor and country before ?> Br;) |
First I downgraded phone with FIG-Downgrade-Board-1048-8.0.0.fcff firmware and TP, log: Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery NOT checked Bypass version check NOT checked Old slow algo NOT checked Force OTA NOT checked Looking for a device in force upgrade mode Device detected: COM32: HUAWEI USB COM 1.0 (COM32) 2020.09.16 19:58:29 Starting to write device in FASTBOOT mode... File to update: C:\Huawei flash\FIG-Downgrade-Board-1048-8.0.0.fcff Device detected: COM32: HUAWEI USB COM 1.0 (COM32) USB Device REMOVAL Type: @oem207.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&3ae11b61&0&4 USB Device INSERTION Type: @oem207.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&3ae11b61&0&4 Process identifier:5332751 Writing bootloader... Step 1... Step 2... Waiting for device REMOVAL/INSERTION... USB Device REMOVAL Type: @oem207.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&3ae11b61&0&4 USB Device INSERTION Type: @oem88.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: XXXXXXXXXXXXXXXX Waiting for fastboot device... Device found: XXXXXXXXXXXXXXXX Looking for a device in fastboot mode Device found: XXXXXXXXXXXXXXXX Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:XXXXXXXXXXXXXXXX IMEI:XXXXXXXXXXXXXXX IMEI1:000000000000000 MEID:00000000000000 Build number: :FIG-LGRP2-OVS 9.1.0.122 Model: FIG-LX1 Vendor/Country: hw/eu Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Erasing ver .. . Writing ptable partition PTABLE partition update ...OK Writing xloader partition XLOADER partition update ...OK Writing fastboot partition FASTBOOT partition update ...OK Writing kernel partition KERNEL partition update ...OK Writing ramdisk partition RAMDISK partition update ...OK Writing vbmeta partition VBMETA partition update ...OK Writing odm partition ODM partition update ...OK Writing recovery_ramdisk partition RECOVERY_RAMDISK partition update ...OK Writing recovery_vendor partition RECOVERY_VENDOR partition update ...OK Writing recovery_vbmeta partition RECOVERY_VBMETA partition update ...OK Erasing cust partition Partition cust erased Erasing misc partition Partition misc erased Erasing cache partition Partition cache erased Writing cache partition CACHE partition update ...OK Writing fw_lpm3 partition FW_LPM3 partition update ...OK Writing fw_hifi partition FW_HIFI partition update ...OK Writing teeos partition TEEOS partition update ...OK Writing trustfirmware partition TRUSTFIRMWARE partition update ...OK Writing sensorhub partition SENSORHUB partition update ...OK Writing dts partition DTS partition update ...OK Writing modemnvm_update partition MODEMNVM_UPDATE partition update ...OK Writing modem_fw partition MODEM_FW partition update ...OK Writing system partition sending sparse file 464714112 bytes Waiting for answer... send sparse file OK sending sparse file 471814356 bytes Waiting for answer... send sparse file OK sending sparse file 389933488 bytes Waiting for answer... send sparse file OK SYSTEM partition update ...OK Writing vendor partition sending sparse file 423649224 bytes Waiting for answer... send sparse file OK sending sparse file 146912460 bytes Waiting for answer... send sparse file OK VENDOR partition update ...OK Erasing product partition Partition product erased Writing product partition PRODUCT partition update ...OK Erasing version partition Partition version erased Writing version partition VERSION partition update ...OK Erasing userdata partition Partition userdata erased Erasing userdata partition Partition userdata erased Writing userdata partition USERDATA partition update ...OK Writing splash2 partition SPLASH2 partition update ...OK Erasing bootfail_info partition Partition bootfail_info erased Erasing dfx partition Partition dfx erased Erasing rrecord partition Partition rrecord erased Waiting for fastboot device... USB Device REMOVAL Type: @oem88.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: XXXXXXXXXXXXXXXX USB Device INSERTION Type: @oem88.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: XXXXXXXXXXXXXXXX Device found: XXXXXXXXXXXXXXXX Waiting for OEM hwdog certify set 0 command ...OK Waiting for OEM oeminfoerase-all command ...OK USB Device REMOVAL Type: @oem88.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: XXXXXXXXXXXXXXXX Software written 2020.09.16 20:07:49 Writing device finished OK Then I readed bootloader code with FlyCaptain, log: 2020-09-16 20:13:57.322 Autodetect started! 2020-09-16 20:13:58.879 Found COM port: COM196 2020-09-16 20:13:58.964 Connecting to server... 2020-09-16 20:14:00.076 Connected! 2020-09-16 20:14:00.079 Read data from server... 2020-09-16 20:14:01.684 Read data from server success! 2020-09-16 20:14:01.690 Open COM port COM196 (Android Adapter PCUI (COM196))... 2020-09-16 20:14:18.476 CP State: ready 2020-09-16 20:14:18.479 Read phone basic info... 2020-09-16 20:14:18.843 Read phone secure info... 2020-09-16 20:14:28.453 Read bootloader code start 2020-09-16 20:14:30.703 Read bootloader code success! 2020-09-16 20:14:30.708 Job finished! Bootloader code 3535415881811828 After I changed Model to FIG-L31, Vendor to hw, Country to eu with FlyCaptain, log: MEID: 00000000000000 pESN: 00000000 IMEI: XXXXXXXXXXXXXXX IMEI 0: 000000000000000 IMEISV: 48 Firmware ver.: System-FAC 8.0.0.037(009F) SN: XXXXXXXXXXXXXXXX Custom SN: DU4MBH1893034234 WiFi MAC: EC:8C:9A:9F:16:B3 BlueTooth MAC: EC:8C:9A:9F:1C:90 FASTBOOT:Chipset-dallas8.0.0.001(02TW)_FASTBOOT BOOT:System-FAC 8.0.0.037(009F)_BOOT RECOVERY:(unknow) SYSTEM:System-FAC 8.0.0.037(009F) MAINVER:System-FAC 8.0.0.037(009F) DATAVER:FIG-L31-BD 1.0.0.48_DATA_FIG-shizhi_hw_default APTIME:Fri Jun 15 02:29:50 CST 2018 RAM: 3G eMMC: 32G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2020-09-16 20:17:33.338 Autodetect started! 2020-09-16 20:17:34.905 Found COM port: COM196 2020-09-16 20:17:35.957 Repairing start New Vendor : hw New Country : eu New Model : FIG-L31 2020-09-16 20:17:35.967 Connecting to server... 2020-09-16 20:17:36.809 Connected! 2020-09-16 20:17:36.812 Read data from server... 2020-09-16 20:17:38.455 Read data from server success! 2020-09-16 20:17:38.460 Open COM port COM196 (Android Adapter PCUI (COM196))... 2020-09-16 20:17:43.688 CP State: ready 2020-09-16 20:17:43.691 Read phone basic info... 2020-09-16 20:17:44.102 Read phone secure info... 2020-09-16 20:17:53.618 Read from server... 2020-09-16 20:17:53.895 Read from server success! 2020-09-16 20:17:54.139 Writing Vendor and Country... 2020-09-16 20:17:54.140 Read from server... 2020-09-16 20:17:54.355 Read from server success! 2020-09-16 20:17:54.564 Writing Vendor and Country success! 2020-09-16 20:17:54.567 Writing device model... 2020-09-16 20:17:54.570 Read from server... 2020-09-16 20:17:54.729 Read from server success! 2020-09-16 20:17:54.914 Write device model success! 2020-09-16 20:17:55.435 Synchronize NV... 2020-09-16 20:17:55.937 Synchronize NV success! 2020-09-16 20:17:55.940 Factory reset... 2020-09-16 20:17:59.467 Factory reset success! 2020-09-16 20:17:59.561 Finished! After I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector. For FIG-L31 I flashed these two files: Figo-L31_8.0.0.128(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XFJ.cfs update_FIG-L31_8.0.0.128(C432)_hw_eu.cfs Log: Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery NOT checked Bypass version check NOT checked Old slow algo NOT checked Force OTA NOT checked Looking for a device in upgrade mode COM196: Android Adapter PCUI (COM196) COM198: DBAdapter Reserved Interface (COM198) 2020.09.16 20:32:15 Starting to write device in UPGRADE mode... No devices detected in fastboot mode Old slow algo NOT selected 2020.09.16 20:32:16 start to write update file File to update: C:\Huawei flash\Figo-L31_8.0.0.128(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XFJ.cfs Process identifier:5332778 Validating file... Detecting port... Preparing to write... Extracting partition SHA256RSA... Writing partition: SHA256RSA...OK Extracting partition CRC... Writing partition: CRC...OK Extracting partition CURVER... Writing partition: CURVER...OK Extracting partition VERLIST... Writing partition: VERLIST...OK Extracting partition PACKAGE_TYPE... Writing partition: PACKAGE_TYPE...OK Extracting partition EFI... Writing partition: EFI...OK Extracting partition XLOADER... Writing partition: XLOADER...OK Extracting partition FW_LPM3... Writing partition: FW_LPM3...OK Extracting partition FASTBOOT... Writing partition: FASTBOOT...OK Extracting partition MODEMNVM_UPDATE... Writing partition: MODEMNVM_UPDATE...OK Extracting partition TEEOS... Writing partition: TEEOS...OK Extracting partition TRUSTFIRMWARE... Writing partition: TRUSTFIRMWARE...OK Extracting partition SENSORHUB... Writing partition: SENSORHUB...OK Extracting partition FW_HIFI... Writing partition: FW_HIFI...OK Extracting partition KERNEL... Writing partition: KERNEL...OK Extracting partition RAMDISK... Writing partition: RAMDISK...OK Extracting partition RECOVERY_RAMDISK... Writing partition: RECOVERY_RAMDISK...OK Extracting partition RECOVERY_VENDOR... Writing partition: RECOVERY_VENDOR...OK Extracting partition ERECOVERY_KERNEL... Writing partition: ERECOVERY_KERNEL...OK Extracting partition ERECOVERY_RAMDISK... Writing partition: ERECOVERY_RAMDISK...OK Extracting partition ERECOVERY_VENDOR... Writing partition: ERECOVERY_VENDOR...OK Extracting partition RECOVERY_VBMETA... Writing partition: RECOVERY_VBMETA...OK Extracting partition ERECOVERY_VBMETA... Writing partition: ERECOVERY_VBMETA...OK Extracting partition DTS... Writing partition: DTS...OK Extracting partition MODEM_FW... Writing partition: MODEM_FW...OK Extracting partition VBMETA... Writing partition: VBMETA...OK Extracting partition ODM... Writing partition: ODM...OK Extracting partition CACHE... Writing partition: CACHE...OK Extracting partition SYSTEM... Writing partition: SYSTEM...OK Extracting partition CUST... Writing partition: CUST...OK Extracting partition VENDOR... Writing partition: VENDOR...OK Extracting partition VERSION... Writing partition: VERSION...OK Extracting partition PRODUCT... Writing partition: PRODUCT...OK Extracting partition USERDATA... Writing partition: USERDATA...OK Software written 2020.09.16 20:45:37 start to update cust file File to update: C:\Huawei flash\update_FIG-L31_8.0.0.128(C432)_hw_eu.cfs Process identifier:5332805 Validating file... Detecting port... Preparing to write... Extracting partition SHA256RSA... Writing partition: SHA256RSA...OK Extracting partition CRC... Writing partition: CRC...OK Extracting partition CURVER... Writing partition: CURVER...OK Extracting partition VERLIST... Writing partition: VERLIST...OK Extracting partition PACKAGE_TYPE... Writing partition: PACKAGE_TYPE...OK Extracting partition EFI... Writing partition: EFI...OK Extracting partition CUST... Writing partition: CUST...OK Extracting partition VERSION... Writing partition: VERSION...OK Extracting partition USERDATA... Writing partition: USERDATA...OK Software written 2020.09.16 20:49:39 Writing device finished OK Then I have readed the bootloader code with FlyCaptain and in cmd got the message: C:\Users\adb>fastboot oem relock 3535415881811828 ... FAILED (remote: stat not match) finished. total time: -0.011s Then I readed Bootloader unlock code again, but I got the same code: Bootloader code 3535415881811828 Whats wrong? :( |
Did you change the model to FIG-L31, vendor: hw country : eu before ?!\ Br;) |
I changed the model to FIG-L31, vendor: hw, country : eu before I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector. I wrote in my post everything in order as I did. |
Downgrade again, read boot code again, relock it and flash after the retail firmware Br;) |
Relock bootloader I have before or after changing model, vendor and country? |
must downgrade, read bootcode again, relock, after change values. And downgrade using the file with NV included Br;) |
I tried, but unsuccessfully. I got the same bootloader unlock code and the same error, when tried to relock bootloader :( |
Sure you downgraded using FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff ? Br;) |
I had to use for downgrade FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff instead of FIG-Downgrade-Board-1048-8.0.0.fcff? |
I told you to do that on previous replies. So yes use that one Br;) |
Now I flashed FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff After I try to read bootloader unlock code, but I got an error: 2020-09-17 16:25:20.575 Read bootloader code start 2020-09-17 16:25:21.586 Read bootloader code fail! 2020-09-17 16:25:21.591 ERROR! Device must be repaired before this operation! Then I repaired model to FIG-L31, vendor: hw, country : eu, and then I already read the bootloader unlock code. It is already different than it was: Bootloader code 4628758773944709 But when I try to relock bootloader with this code, I got the same error: C:\Users\adb>fastboot oem relock 4628758773944709 ... FAILED (remote: stat not match) finished. total time: -0.011s |
