Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 09-10-2020, 19:30   #1 (permalink)
YOO
Member: 154051
Thanks Meter: 29
How to relock bootloader on Huawei FIG-L11 and ANE-L21 ?
Hi, I have Huawei P Smart (FIG-L11) and P20 Lite (ANE-L21). How I can relock bootloader for these phones? Because they had the annoying message at startup:
"The device had been unlocked and can't be trusted".
Both phones are after successfully downgrading using Resurrector with TP and downgrade firmware. For FIG-L11 I flashed:
FIG-Downgrade-Board-1048-8.0.0.fcff
After I changed Model to FIG-L11, Vendor to hw, Country to eu with FlyCaptain.
After I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector. For FIG-L11 I flashed these two files:
Figo-L11_8.0.0.129(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XUW.cfs
update_FIG-L11_8.0.0.129(C432)_hw_eu.cfs
Then unlocked the phone and I have readed the bootloader code with FlyCaptain and in cmd got the message:
C:\Users\adb>fastboot oem relock 3017477598189510
FAILED (remote: stat not match)
finished. total time: -0.000s
With Huawei P20 Lite I have the same problem.
WHY I CAN'T RELOCK BOOTLOADER?? PLEASE HELP ME TO RELOCK BOOTLOADER!!!
Old 09-12-2020, 07:16   #2 (permalink)
Member: 521590
Thanks Meter: 55
Same message at startup, same problem here......
Old 09-12-2020, 07:49   #3 (permalink)
YOO
Member: 154051
Thanks Meter: 29
.:hack3r2k:. or other product manager, please help us!!!
Old 09-14-2020, 11:38   #4 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 57,453
Seems the code is wrong. Can you try reading again ? Also post a full detect log. Also can be from incompatible fw . Did you set correct model vendor and country before ?>
Old 09-16-2020, 19:02   #5 (permalink)
YOO
Member: 154051
Thanks Meter: 29
First I downgraded phone with FIG-Downgrade-Board-1048-8.0.0.fcff firmware and TP, log:
Standard update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery NOT checked
Bypass version check NOT checked
Old slow algo NOT checked
Force OTA NOT checked
Looking for a device in force upgrade mode
Device detected:
COM32: HUAWEI USB COM 1.0 (COM32)
2020.09.16 19:58:29 Starting to write device in FASTBOOT mode...
File to update: C:\Huawei flash\FIG-Downgrade-Board-1048-8.0.0.fcff
Device detected:
USB Device REMOVAL
Type: @oem207.inf,%huawei06%;HUAWEI USB COM 1.0
VidPid: VID_12D1&PID_3609
Instance id: 6&3ae11b61&0&4
USB Device INSERTION
Process identifier:5332751
Writing bootloader...
Step 1...
Step 2...
Waiting for device REMOVAL/INSERTION...
USB Device REMOVAL
Type: @oem88.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: XXXXXXXXXXXXXXXX
Waiting for fastboot device...
Device found: XXXXXXXXXXXXXXXX
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:XXXXXXXXXXXXXXXX
IMEI:XXXXXXXXXXXXXXX
IMEI1:000000000000000
MEID:00000000000000
Build number: :FIG-LGRP2-OVS 9.1.0.122
Model: FIG-LX1
Vendor/Country: hw/eu
Battery state: 0
OEM lock state info:
FB LockState: UNLOCKED
USER LockState: LOCKED
OEM get bootinfo:
unlocked
Erasing ver .. .
Writing ptable partition
PTABLE partition update ...OK
Writing xloader partition
XLOADER partition update ...OK
Writing fastboot partition
FASTBOOT partition update ...OK
Writing kernel partition
KERNEL partition update ...OK
Writing ramdisk partition
RAMDISK partition update ...OK
Writing vbmeta partition
VBMETA partition update ...OK
Writing odm partition
ODM partition update ...OK
Writing recovery_ramdisk partition
RECOVERY_RAMDISK partition update ...OK
Writing recovery_vendor partition
RECOVERY_VENDOR partition update ...OK
Writing recovery_vbmeta partition
RECOVERY_VBMETA partition update ...OK
Erasing cust partition
Partition cust erased
Erasing misc partition
Partition misc erased
Erasing cache partition
Partition cache erased
Writing cache partition
CACHE partition update ...OK
Writing fw_lpm3 partition
FW_LPM3 partition update ...OK
Writing fw_hifi partition
FW_HIFI partition update ...OK
Writing teeos partition
TEEOS partition update ...OK
Writing trustfirmware partition
TRUSTFIRMWARE partition update ...OK
Writing sensorhub partition
SENSORHUB partition update ...OK
Writing dts partition
DTS partition update ...OK
Writing modemnvm_update partition
MODEMNVM_UPDATE partition update ...OK
Writing modem_fw partition
MODEM_FW partition update ...OK
Writing system partition
sending sparse file 464714112 bytes
Waiting for answer...
send sparse file OK
sending sparse file 471814356 bytes
send sparse file OK
sending sparse file 389933488 bytes
send sparse file OK
SYSTEM partition update ...OK
Writing vendor partition
sending sparse file 423649224 bytes
send sparse file OK
sending sparse file 146912460 bytes
send sparse file OK
Erasing product partition
Partition product erased
Writing product partition
PRODUCT partition update ...OK
Erasing version partition
Partition version erased
Writing version partition
VERSION partition update ...OK
Erasing userdata partition
Partition userdata erased
Writing userdata partition
USERDATA partition update ...OK
Writing splash2 partition
SPLASH2 partition update ...OK
Erasing bootfail_info partition
Partition bootfail_info erased
Erasing dfx partition
Partition dfx erased
Erasing rrecord partition
Partition rrecord erased
USB Device REMOVAL
Waiting for OEM hwdog certify set 0 command ...OK
Waiting for OEM oeminfoerase-all command ...OK
USB Device REMOVAL
Software written
2020.09.16 20:07:49 Writing device finished OK
Then I readed bootloader code with FlyCaptain, log:
2020-09-16 20:13:57.322 Autodetect started!
2020-09-16 20:13:58.879 Found COM port: COM196
2020-09-16 20:13:58.964 Connecting to server...
2020-09-16 20:14:00.076 Connected!
2020-09-16 20:14:00.079 Read data from server...
2020-09-16 20:14:01.684 Read data from server success!
2020-09-16 20:14:01.690 Open COM port COM196 (Android Adapter PCUI (COM196))...
2020-09-16 20:14:18.476 CP State: ready
2020-09-16 20:14:18.479 Read phone basic info...
2020-09-16 20:14:18.843 Read phone secure info...
2020-09-16 20:14:28.453 Read bootloader code start
2020-09-16 20:14:30.703 Read bootloader code success!
2020-09-16 20:14:30.708 Job finished!
Bootloader code 3535415881811828
After I changed Model to FIG-L31, Vendor to hw, Country to eu with FlyCaptain, log:
MEID: 00000000000000
pESN: 00000000
IMEI: XXXXXXXXXXXXXXX
IMEI 0: 000000000000000
IMEISV: 48
Firmware ver.: System-FAC 8.0.0.037(009F)
SN: XXXXXXXXXXXXXXXX
Custom SN: DU4MBH1893034234
WiFi MAC: EC:8C:9A:9F:16:B3
BlueTooth MAC: EC:8C:9A:9F:1C:90
FASTBOOT:Chipset-dallas8.0.0.001(02TW)_FASTBOOT
BOOT:System-FAC 8.0.0.037(009F)_BOOT
RECOVERYunknow)
SYSTEM:System-FAC 8.0.0.037(009F)
MAINVER:System-FAC 8.0.0.037(009F)
DATAVER:FIG-L31-BD 1.0.0.48_DATA_FIG-shizhi_hw_default
APTIME:Fri Jun 15 02:29:50 CST 2018
RAM: 3G
eMMC: 32G
IMEI 1 Sim Lock status:
NET: locked, unlock retry counts: 10
NETSUB: unlocked
SP: unlocked
2020-09-16 20:17:33.338 Autodetect started!
2020-09-16 20:17:34.905 Found COM port: COM196
2020-09-16 20:17:35.957 Repairing start
New Vendor : hw
New Country : eu
New Model : FIG-L31
2020-09-16 20:17:35.967 Connecting to server...
2020-09-16 20:17:36.809 Connected!
2020-09-16 20:17:36.812 Read data from server...
2020-09-16 20:17:38.455 Read data from server success!
2020-09-16 20:17:38.460 Open COM port COM196 (Android Adapter PCUI (COM196))...
2020-09-16 20:17:43.688 CP State: ready
2020-09-16 20:17:43.691 Read phone basic info...
2020-09-16 20:17:44.102 Read phone secure info...
2020-09-16 20:17:53.618 Read from server...
2020-09-16 20:17:53.895 Read from server success!
2020-09-16 20:17:54.139 Writing Vendor and Country...
2020-09-16 20:17:54.140 Read from server...
2020-09-16 20:17:54.355 Read from server success!
2020-09-16 20:17:54.564 Writing Vendor and Country success!
2020-09-16 20:17:54.567 Writing device model...
2020-09-16 20:17:54.570 Read from server...
2020-09-16 20:17:54.729 Read from server success!
2020-09-16 20:17:54.914 Write device model success!
2020-09-16 20:17:55.435 Synchronize NV...
2020-09-16 20:17:55.937 Synchronize NV success!
2020-09-16 20:17:55.940 Factory reset...
2020-09-16 20:17:59.467 Factory reset success!
2020-09-16 20:17:59.561 Finished!
After I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector. For FIG-L31 I flashed these two files:
Figo-L31_8.0.0.128(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XFJ.cfs
update_FIG-L31_8.0.0.128(C432)_hw_eu.cfs
Log:
Standard update
Looking for a device in upgrade mode
COM196: Android Adapter PCUI (COM196)
COM198: DBAdapter Reserved Interface (COM198)
2020.09.16 20:32:15 Starting to write device in UPGRADE mode...
No devices detected in fastboot mode
Old slow algo NOT selected
2020.09.16 20:32:16 start to write update file
File to update: C:\Huawei flash\Figo-L31_8.0.0.128(C432)_Firmware_Android_8.0.0_EMUI_8. 0.0_05014XFJ.cfs
Process identifier:5332778
Validating file...
Detecting port...
Preparing to write...
Extracting partition SHA256RSA...
Writing partition: SHA256RSA...OK
Extracting partition CRC...
Writing partition: CRC...OK
Extracting partition CURVER...
Writing partition: CURVER...OK
Extracting partition VERLIST...
Writing partition: VERLIST...OK
Extracting partition PACKAGE_TYPE...
Writing partition: PACKAGE_TYPE...OK
Extracting partition EFI...
Writing partition: EFI...OK
Extracting partition XLOADER...
Writing partition: XLOADER...OK
Extracting partition FW_LPM3...
Writing partition: FW_LPM3...OK
Extracting partition FASTBOOT...
Writing partition: FASTBOOT...OK
Extracting partition MODEMNVM_UPDATE...
Writing partition: MODEMNVM_UPDATE...OK
Extracting partition TEEOS...
Writing partition: TEEOS...OK
Extracting partition TRUSTFIRMWARE...
Writing partition: TRUSTFIRMWARE...OK
Extracting partition SENSORHUB...
Writing partition: SENSORHUB...OK
Extracting partition FW_HIFI...
Writing partition: FW_HIFI...OK
Extracting partition KERNEL...
Writing partition: KERNEL...OK
Extracting partition RAMDISK...
Writing partition: RAMDISK...OK
Extracting partition RECOVERY_RAMDISK...
Writing partition: RECOVERY_RAMDISK...OK
Extracting partition RECOVERY_VENDOR...
Writing partition: RECOVERY_VENDOR...OK
Extracting partition ERECOVERY_KERNEL...
Writing partition: ERECOVERY_KERNEL...OK
Extracting partition ERECOVERY_RAMDISK...
Writing partition: ERECOVERY_RAMDISK...OK
Extracting partition ERECOVERY_VENDOR...
Writing partition: ERECOVERY_VENDOR...OK
Extracting partition RECOVERY_VBMETA...
Writing partition: RECOVERY_VBMETA...OK
Extracting partition ERECOVERY_VBMETA...
Writing partition: ERECOVERY_VBMETA...OK
Extracting partition DTS...
Writing partition: DTS...OK
Extracting partition MODEM_FW...
Writing partition: MODEM_FW...OK
Extracting partition VBMETA...
Writing partition: VBMETA...OK
Extracting partition ODM...
Writing partition: ODM...OK
Extracting partition CACHE...
Writing partition: CACHE...OK
Extracting partition SYSTEM...
Writing partition: SYSTEM...OK
Extracting partition CUST...
Writing partition: CUST...OK
Extracting partition VENDOR...
Writing partition: VENDOR...OK
Extracting partition VERSION...
Writing partition: VERSION...OK
Extracting partition PRODUCT...
Writing partition: PRODUCT...OK
Extracting partition USERDATA...
Writing partition: USERDATA...OK
Software written
2020.09.16 20:45:37 start to update cust file
File to update: C:\Huawei flash\update_FIG-L31_8.0.0.128(C432)_hw_eu.cfs
Process identifier:5332805
Validating file...
Detecting port...
Software written
2020.09.16 20:49:39 Writing device finished OK
Then I have readed the bootloader code with FlyCaptain and in cmd got the message:
C:\Users\adb>fastboot oem relock 3535415881811828
finished. total time: -0.011s
Then I readed Bootloader unlock code again, but I got the same code:
Whats wrong?
Old 09-16-2020, 21:18   #6 (permalink)
Member: 15022
Sonork: 100.53452
Did you change the model to FIG-L31, vendor: hw country : eu before ?!\
Old 09-17-2020, 06:28   #7 (permalink)
YOO
Member: 154051
Thanks Meter: 29
I changed the model to FIG-L31, vendor: hw, country : eu before I flashed firmware (low version for repair purposes) in UPGRADE mode with Resurrector.
I wrote in my post everything in order as I did.
Old 09-17-2020, 08:18   #8 (permalink)
Member: 15022
Sonork: 100.53452
Downgrade again, read boot code again, relock it and flash after the retail firmware
Old 09-17-2020, 08:25   #9 (permalink)
YOO
Member: 154051
Thanks Meter: 29
Relock bootloader I have before or after changing model, vendor and country?
Old 09-17-2020, 08:27   #10 (permalink)
Member: 15022
Sonork: 100.53452
must downgrade, read bootcode again, relock, after change values. And downgrade using the file with NV included
Old 09-17-2020, 11:54   #11 (permalink)
YOO
Member: 154051
Thanks Meter: 29
I tried, but unsuccessfully. I got the same bootloader unlock code and the same error, when tried to relock bootloader
Old 09-17-2020, 11:55   #12 (permalink)
Member: 15022
Sonork: 100.53452
Sure you downgraded using FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff ?
Old 09-17-2020, 12:08   #13 (permalink)
YOO
Member: 154051
Thanks Meter: 29
I had to use for downgrade FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff instead of FIG-Downgrade-Board-1048-8.0.0.fcff?
Old 09-17-2020, 14:25   #14 (permalink)
Member: 15022
Sonork: 100.53452
I told you to do that on previous replies. So yes use that one
Old 09-17-2020, 15:48   #15 (permalink)
YOO
Member: 154051
Thanks Meter: 29
Now I flashed FIG-Full-Repair-NV-included-Board-1048-8.0.0.fcff
After I try to read bootloader unlock code, but I got an error:
2020-09-17 16:25:20.575 Read bootloader code start
2020-09-17 16:25:21.586 Read bootloader code fail!
2020-09-17 16:25:21.591 ERROR!
Device must be repaired before this operation!
Then I repaired model to FIG-L31, vendor: hw, country : eu, and then I already read the bootloader unlock code. It is already different than it was:
Bootloader code 4628758773944709
But when I try to relock bootloader with this code, I got the same error:
C:\Users\adb>fastboot oem relock 4628758773944709
Page generated in 0.45769 seconds with 7 queries
