Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 05-14-2014, 12:35   #1 (permalink)
pearsonjohnboy's Avatar
Member: 214417
Thanks Meter: 21
Motorola Atrix code not work
Sent two orders off one is fine but the other don't work can you check with supplier please remote unlock order 20731
Old 05-14-2014, 14:40   #2 (permalink)
Member: 214417
Thanks Meter: 21
been looking into this and found the following, One unfortunate feature of the Motorola Atrix is that if you try to unlock it with an invalid network unlock code more than ten times, it will permanently lock up. After this point, no matter which SIM card you insert (even the one from your own carrier), you will be given a dialogue to enter your network unlock code. However, even if you enter the correct unlock code at this point, it will not work.
So with this model you need to check that is works with its own network sim first.
The following link is supposed to be a fix for this problem, I will only try if the customer wants to pay more money.
Amil's Website: How to Fix a "Permanently" Network-Locked Atrix Phone
Old 05-14-2014, 16:47   #3 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,605
If you have the code better to flash it without asking any extra. Aint much of a job doing this
br
Page generated in 0.12075 seconds with 8 queries
