how to unlock nec and sanyo using furious box dear, i have problem for unlocking nec e616 and sanyo 801 . i already try with furious box but i can't understand how to install com port and etc . but i try with com cable and usb cable . installed driver also driver is ok pl give me unlock setup . if open software and use unlock button only surching phone |
unlock nec e616 use rj45 sharp gx30. correct me if wrong. br. tubansel |
YES YOU ARE RITE TESTED MANY TIMES BUT PROBLEM COMES IF SET'S JAK IS RUSTED CLEAN IT OR CHECK IF ITS NOT DAMAGED BR GSMCRAZY1 |
i alreay checked all cables pl give another solutions |
mate, i think you need a long press in power button, til the software detect before you do release the button... |
I advice you next time you give advices to be sure about what ur talking about. On Nec 616 , sanyo 901 theres no need to press any button as phones must be on and thats all. Br;) |
what is the very easy method for nec 3g and sanyo 801 unlock usb cable or rj45 both cable i try but can't find phone and usb moem pl |
Reading info... Failed to open the communication port ! Error ... ! Ready... Time needed - 00:00:00 |
You must click FTDI USE. I dont think is hard understand "Failed to open the communication port !" isnt related to phone communication pb. Br;) |
i already changed usb / rj45 cable and check with different phone but problem same pl give me corect method for nec and sanyo unlock ( my box connected usb and com same time ) |
