How to work with 2-3 boxes simultaneously! As you all know using more then 1 unlocking/flashing tool is not possible. I tried many times to make working in the same time, JAF, FURIOUS and UBBOX for example but i didn;t succed because almost all box producers are using the same ftdi drivers and the same port . Of course one of the option is to install VMware and use one box per one image installed in you pc but for that you need a NASA pc since you need to use 10boxes at a time. So, my question is..how we can make to work in the same time more devices? i want to flash somthing with JAF and unlock with Furious in the same time. Anyone had succed ? si there any chance to resolve this at least for FG? Thank you |
For FG you can open multiple exes from the same pack at the same time Also you will have to connect several comport cables or boxes, all is possible! eg. Open 2 TOSHIBA modules and service two phones at a time COM1 + COM2 For Jaf this is not possible, because of ****ty protection, UB only one per computer ! BR Max_B |
if anyone can help me out...i'll be appriciate. regards. |
BR Max_B |
im working at the same computer with this box at the same time: setool, jaf, furious gold and ustpro2 without installing any other softwar, just change the comport for box, it means give to box a specific comport number, so all be ok and no conflit on pc, its better to install ustpro first ;) |
any more help.....???????? |
BR |
first you need to know dongel protection driver exp setool: Axalto-egate-drivers FG : Rokey 5 EUB: rokey 5 expl: FG and EUB dont use it at same port you kill smart card FG an jaf mybe worcking you need to see device info about comport use'it USB1 USB2, on your computer most have conflit if you plug more device the power comsuption is low and device not work perfectly |
iam using 17 box in one pc...besides the 4 pc ports i use pci usb so there is 9 ports now plus 2 in front to make 10 usb...now you need to know the combination of box so it wont have conflict...good luck.. |
if have more work buy other pc and all its ok no need to use 10000box in one pc |
We are in two thousand fuccking ten :D BR Max_B |
Can you please give us your order and wich com ports you use? Thanks |
