10-12-2020, 13:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | Huawei 5 prime 2018 DRA-LX2 testpoint needed [SOLVED] cause i got error when i try to flash it without test point |
10-14-2020, 18:10 | #3 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | i got error when i try to flash it without test point Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM7)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM7 ERROR: Connection failed ! ERROR: BOOT_PHONE; |
10-15-2020, 07:20 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Do you connect with vol up+down pressed as the software is telling ? Because seems your not ! Be sure the battery is charged. Also try to reatatch battery before connection. Also be sure no pc sync utilities started that could open the port before. If same issue contact me over Telegram https://t.me/AXUxsBdkbULJ6EvYhVGoUg Br Last edited by .:hack3r2k:.; 10-15-2020 at 07:38. |
10-15-2020, 11:40 | #5 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | great thx Brother .:hack3r2k:. Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM7)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM7 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 51ee4174edbc212fbc0646c303e3c2ed Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CA00, 00, 6739, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xF83BD432 0x89A5FCF4 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEC000000 SIZE: 0x2BE3FBE00 Loading the file ... Cfg done ... Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:08:12 Log file saved to: LOG_15_10_2020_12_33_50.txt |
