Huawei G2157 not unlocked first i use TMN2000 Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: DBG_P1.1KK01V01.06 Imei: 358144032994950 SIGN READ FAILED ! Error ... ! Time needed - 00:00:02 after that T156old Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: DBG_P1.1KK01V01.06 Imei: 358144032994950 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:04 still locked to provider how to unlock |
Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: DBG_P1.1KK01V01.06 Imei: 358144032994950 SIGN READ FAILED ! Error ... ! Time needed - 00:00:01 |
Use latest version and select correct phone model. |
then unlock |
Br;) |
Software engine version: 1.0.0.6331 Connect phone powered on ! Start auth ! SW Ver: DBG_P1.1KK01V01.06 Imei: 358144032994950 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting unsupported firmware dump; Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 3A 85 98 64 01 15 09 Flash ID(0): 00C2:22A7 Saved: ULC2_10.10.57_28.12.2011_FLASH.bin Done ! Time needed - 00:06:49 Deposit Files |
Second G2157 not powering on after trying to flash Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1KK01V01.05 Imei: 358144033076666 SIGN READ FAILED ! Error ... ! Time needed - 00:00:05 Software engine version: 1.0.0.6331 Press power on ! Error ... ! Time needed - 00:00:26 |
What flash ? I told you to do restore using G2157_REL_P1.1KK01V01.05_FULL_REST.bin. If you did that must work but probably you batt is too low so charge it Br;) |
Ok i was wrong i wrote instead Restore (flash) i didnt flash restore and choose file from support G2157_REL_P1.1KK01V01.05_FULL_REST.bin but even restore didnt pass now phone is not powerinf off what can i do |
Is there any news for me |
Br;) |
Software engine version: 1.0.0.6331 Press power on ! Error ... ! Time needed - 00:00:26 is there any other way sir to solve the problem changed battery no change phone not powering what about dump did you check |
f1st try to restore with backup file after backup unlock |
there are 2 g2157 first is has backup and send second phone not powering on |
is there any news from dump i have send |
