02-10-2020, 16:51 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042338 Status: Offline Thanks Meter: 8 | unlock S.E. k800i [SOLVED] i have 2 sony ericsson and i want unlock them but not work directly, witch file need download for flash and how understand because their is thousand file i wirk with se-fut sofware |
02-11-2020, 22:53 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Must reflash phone with firmware + cust from support. cid 52 and after unlock by selecting the flashed file Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
02-13-2020, 16:27 | #3 (permalink) |
Member: 1042338 Status: Offline Thanks Meter: 8 | Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 49 OTP Lock Stat.: 1 OTP Imei : 3517080198**** PAF: 1 Color : RED Erom Cert. ID : 49 Flash Chip ID : 897E [UNLOCK START] Press Power On shortly ! Phone detected ... [UNLOCK END] Error ... ! Operation Time - 00:00:14 i receive this error read info: Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 49 OTP Lock Stat.: 1 OTP Imei : 3517080198**** PAF: 1 Color : RED Erom Cert. ID : 49 Flash Chip ID : 897E [PHONE INFO] MODEL: MODEL MAPP CXC article: R1CF001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1CF001 Language Pack.: S_E_EUROPE CDA article.: CDA_NUMBER CDA version.: CDA_REVISION Default article.: cxc1250490 Default version.: R1ED001 Operator: 000-00 Locked: NO Operation Time - 00:00:08 and the phone ask PHONE LOCK CODE |
02-14-2020, 11:46 | #4 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | You phone has user code. Doesn't need unlock. Simply reflash the phone using a cid49 firmware Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
02-14-2020, 15:59 | #5 (permalink) |
Member: 1042338 Status: Offline Thanks Meter: 8 | Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 49 OTP Lock Stat.: 1 OTP Imei : 35170801981439 PAF: 1 Color : RED Erom Cert. ID : 49 Flash Chip ID : 897E [FLASH INIT STARTED] Loading ... Loader version: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Loading ... Loader version: 060721 1022 HANCXC1329129_DB2020_FLASHLOADER_R2A001 [FLASH INIT ENDED] [FLASH WRITE STARTED] Writting: K800I_CXC1250210_GENERIC_R1ED001_RED49.fw Blocks: 455 CID: 49 Write Status: ERROR [FLASH WRITE ENDED] Operation Time - 00:09:25 not work |
