11-05-2019, 16:20 | #16 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | I have a CLT-AL00 with huawei id. Is above informations till valid to fix/flash and chnge oem on this phone. I dont want a brick afterwards. Please guide me. I was looking at some other thread mentioning huawei flash file download is working with imei activation. is this information correct? regards |
11-05-2019, 16:22 | #17 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Ofcourse its still valid Sent from my iPhone using Tapatalk Pro | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
11-06-2019, 13:16 | #18 (permalink) | |
Member: 143848 Status: Offline Thanks Meter: 125 | Quote:
Fly Captain Huawei Resurrector 0.0.0.40 user:C14xxxx Device detected: COM2193: HUAWEI USB COM 1.0 (COM2193) BOOTLOADER File to update: Kirin970_T2_A8.1_V5 OEM File to update: CLT-L29 06/11/2019 11:33:33 Starting to write device... Process identifier:4788480 Writing bootloader... Step 1... Step 2... Step 3... Waiting for device REMOVAL/INSERTION... Waiting for fastboot device... USB Device REMOVAL Type: @oem181.inf,%qcomdevice00%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 8&286e5a22&0&3 USB Device INSERTION Type: @oem41.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 8&286e5a22&0&3 Device found: D5F0218521001428 Looking for a device in fastboot mode Device found: D5F0218521001428 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN5F0218521001428 IMEI:869377036303172 IMEI1:869377036348557 MEID:A000008EC7D6CB Build number: :CLT-AL00 9.1.0.321(C00E320R1P1) Model: CLT-AL00 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Writing OEMINFO partition OEMINFO partition update ...OK Software written 06/11/2019 11:34:20 Writing device finished OK However flashing next step its hard for me. I have downloaded HUAWEI P20 PRO CLT-L29 HW EU HLRCF CHARLOTTE-L29C 9.0.0.236(C432E5R1P9) FIRMWARE 9.0.0 R3 EMUI9.0.0 05015AMH.ZIP Inside phone is CLT-AL00 9.1.0.321(C00E320R1P1 if must flash 9.1 where can i download it. how can i flash with it. resurrector does not recognise the zip or dload. will i be able downgrade it ? | |
11-06-2019, 13:17 | #19 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | you write on upgrade mode (vol up+down and insert usb) not FASTBOOT Br |
11-06-2019, 13:55 | #20 (permalink) | |
COM1984: Android Adapter PCUI (COM1984) COM1985: DBAdapter Reserved Interface (COM1985) 06/11/2019 12:51:01 Starting to write device in UPGRADE mode... Device found: D5F0218521001428 Old slow algo NOT selected 06/11/2019 12:51:04 start to write update file File to update: G:\MOBILES\Huawei\Huawei P20 Pro CLT-L29 hw eu HLRCF Charlotte-L29C 9.0.0.236(C432E5R1P9) Firmware 9.0.0 r3 EMUI9.0.0 05015AMH\Software\dload\update_sd_base\UPDATE.APP File size: 7,240,186,672 bytes Current version(BASE_VER): Charlotte_EMUI9.0.0_Global Process identifier:4788677 Validating file... Detecting port... Preparing to write... Writing file 1 of 43: SHA256RSA...OK Writing file 2 of 43: CRC...OK Writing file 3 of 43: BASE_VERLIST...OK Writing file 4 of 43: BASE_VER...OK Writing file 5 of 43: PACKAGE_TYPE...OK Writing file 6 of 43: HISIUFS_GPT...OK Writing file 7 of 43: XLOADER...OK Writing file 8 of 43: FASTBOOT...OK Writing file 9 of 43: DTS...OK Writing file 10 of 43: DTO...OK Writing file 11 of 43: VECTOR...OK Writing file 12 of 43: FW_LPM3...OK Writing file 13 of 43: HHEE...OK Writing file 14 of 43: TEEOS...OK Writing file 15 of 43: TRUSTFIRMWARE...OK Writing file 16 of 43: SENSORHUB...OK Writing file 17 of 43: FW_HIFI...OK Writing file 18 of 43: KERNEL...OK Writing file 19 of 43: VBMETA...OK Writing file 20 of 43: MODEMNVM_UPDATE...OK Writing file 21 of 43: MODEMNVM_CUST...OK Writing file 22 of 43: RECOVERY_RAMDISK...OK Writing file 23 of 43: RECOVERY_VENDOR...OK Writing file 24 of 43: RECOVERY_VBMETA...OK Writing file 25 of 43: ERECOVERY_KERNEL...OK Writing file 26 of 43: ERECOVERY_RAMDISK...OK Writing file 27 of 43: ERECOVERY_VENDOR...OK Writing file 28 of 43: ERECOVERY_VBMETA...OK Writing file 29 of 43: ENG_VENDOR...OK Writing file 30 of 43: ENG_SYSTEM...OK Writing file 31 of 43: HDCP...OK Writing file 32 of 43: CACHE...OK Procesing .. .. Error downloading file 33 of 43 Error writing software 06/11/2019 12:51:52 Writing device finished with ERROR | |
11-06-2019, 14:03 | #21 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Use the files from the support. Must write both firmware and customisation at once. Be sure enough space on hdd and latest version v40 used Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
11-07-2019, 12:31 | #22 (permalink) | |||
Member: 143848 Status: Offline Thanks Meter: 125 | ID still on Quote:
However HUAWEI ID still on... I can enter phone in safe mode now. | |||
12-18-2019, 21:37 | #29 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1658652 Status: Offline Thanks Meter: 9 | can someone share eml-l29 files because the one i downloaded give error on flash. i am also using the customization file. if i use the customization file alone it works fine but firmware file gives error. |
