01-22-2018, 20:48 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Vodafone VFD510 no network after unlock ? Android 7.1.1 unlock went fine but no network Any Idea ? Code: Software engine version: 1.0.0.10622 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Sep 9 2017 02:01:00 RELEASE DATE : May 10 2017 19:00:00 FIRMWARE INFO : MPSS.JO.3.0-00291-8909_GEN_PACK-1.97872.1.98558.1 IMEI : 35224909168889-2 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: IT_MR1_VDF_P809V51V1.0.0B05 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Program Files\FURIOUS-GOLD\PACK5\35224909168889_22_01_2018_20_43_15.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM5 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM4)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_22_01_2018_20_46_14.txt Time needed - 00:03:02 |
01-22-2018, 22:15 | #2 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | Solved ,,, For other members maybe it will help. Make Factory Reset from Menu not via Vol UP+Power, why factory from menu work and from buttons dont i dunno, but i get network signal. Additional Info (Decided to test to see what will happen if i use org carrier after unlock) In mine case After unlock and factory reset to get network signal with T Mobile carrier everything was fine. Then i use Vodafone sim, turn phone on and make a call to see what will happen if i use org carrier. When i switch to Tmobile again i got message NON Vodafone SIM inserted, so it has been re-locked by carrier i though. Short Info Unlock - if no network make factory reset via menu Don't use Vodafone Sim Card Regards |
The Following 3 Users Say Thank You to Formingus For This Useful Post: |
02-01-2018, 10:55 | #3 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,571 | I will add modem downgrade on the next update for this fw version. Should solve this pb i think Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
