Huawei Y360 wont unlock after flash [SOLVED] Hi, Got a Huawei Y360 to flash. Flashed it with file from support and it powers up fine. But need to unlock it for it to accept network. Keep getting error: Code: Using library Brom_DLL_v7.1413.5 |
I also noticed that it was saying Get part erro so I tried to read partion got the following:- Code: Using library Brom_DLL_v7.1413.5 |
Help!!!!! I cant unlock the Y360 after flash from support |
Use MTKReader to unlock it. Br;) |
Code: Searching phone; |
Br;) |
same problem customers phone needed flashng used file on support now its simlocked without solution tried what was posted also |
I told here to be contacted over skype to check Br;) |
Several days ago was the new year so obviously not at work br;) |
solved by fashing Y360-U61_V100R001C577B106_Firmware_general_05021VMR-BLU.osp from support thanks Hack! |
??? hi, can you give me some explication about how to flash huawei y360? what module do i have to use? |
OTSmart PACK 6 Br;) |
thanks, but i cant see the model in it Y360, which model i need to select? |
