07-21-2020, 10:38 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Get from the support area SPDTooL_v1.0.0.4037.zip, go BOOT MODE, select ITEL P36 (w6501) , choose FRP reset and connect the phone. Simple as that ! Br |
07-21-2020, 14:47 | #5 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Also if stops at syncing means wrong boot mode. try reattach batt and retry with vol up or vol down pressed or both. For sure it must boot Br |
07-22-2020, 12:40 | #7 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
man can you stop telling nonsense things and do what i ask you to do ? Ignore what you see as cpu on the sdptool and do what i asked. Br | |
08-01-2020, 12:45 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: tunisia
Member: 1517638 Status: Offline Sonork: 100.1620436 Thanks Meter: 33 | Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem43.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM7]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; |
08-10-2020, 14:42 | #9 (permalink) | |
Connect in diag mode using one of the generic methods and paste the log | |
11-28-2020, 10:14 | #10 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
Code: Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem143.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM45]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_18B_ITEL_W19.28.5_P11_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_ITEL_W19.28.5_P11 HW Version: sc9863A_modem 05-20-2020 19:25:15 Build number: L6501-F6311-9.0-OP-V038-20200826 PHONE INFO: BT ADDR: SW IMEI[0]: 353946-11-208092-1 SW IMEI[1]: 353946-11-208093-9 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Starting factory reset; Modem imei: 353946112080921 Working; Done ! Log file saved to: LOG_28_11_2020_11_10_26.txt Time needed - 00:00:11 I have Frp problem | |
