11-30-2016, 17:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | tecno t635 not unlock Phone detected (@oem306.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: T635-Etisalat-NL02-20140508-MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 352626-06-044470-6 Reading simlock info; Unlock codes: Time needed - 00:00:21 Log file saved to: LOG_30_11_2016_17_42_23.txt |
11-30-2016, 17:52 | #2 (permalink) |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | i chose huawei/doro/verykool/blu/aeg mtk[serial/usb] i used usb cable everything now ok Searching phone; Phone detected (@oem306.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: T635-Etisalat-NL02-20140508-MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 352626-06-044470-6 Reading simlock info; Unlock codes: Locked to: 621-60 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 |
The Following User Says Thank You to TBOUY For This Useful Post: |
