11-29-2016, 22:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | 5056a frp error Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem234.inf,%qcomdevice71025%;ALCATEL Diagnostics Interface 7102) Preparing to start flash mode; Preparing to open COM15 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01460800209262-9 PTH: 13 PTS: A4U PROV_ID: 5056A-2FC9JMD SBTADDR: 28:BE:03D:19:62 SWIFIADDR: 28:BE:03:E17:E8 HS_PN: SAA1F51WA10C SSN: L3KC07CKAMZ01EP Work id: 07688C0C Done; SECURITY: XHA0OP08BR10 Size: 0000031D Backup saved to: 01460800209262-9 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; FRPEx Done; Log file saved to: LOG_28_11_2016_15_22_15.txt Time needed - 00:00:18 |
11-30-2016, 15:47 | #3 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | got it done via system bug , got in operating system manually, encrypt phone use pin, install google acct and do factory reset from system menu. removed frp on my 5056a digicel 6.0.1 android security patch: june 1, 2016 baseband: msm8909 12110 15w46 kernel: 3.10.49-gda21a9c android-bld@es241 #1 Sat May 28 12:59:59 CST 2016 build:01002 |
The Following User Says Thank You to mrfixit For This Useful Post: |
