03-24-2021, 17:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | k20 downgrade flash Can you upload to the support flashfile for LG X120EMW model? ( I didnt find any flash on internet) I need downgrade because new version is not supported for imei repair. Operation completed, but imei not changed. Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5195 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0404) Preparing to start flash mode; Preparing to open COM13 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 96 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X12011c secure_device = S laf_sw_version = 1.1 device_factory_version = LMX120EMWAT-00-V11c-EEA-XX-JAN-25-2021+0 device_factory_out_version = LMX120EMWAT-00-V11c-EEA-XX-JAN-25-2021+0 pid = WI13S190919005529 imei = 35627610426XXXX model_name = LM-X120EMW device_build_type = U chipset_platform = mt6739 target_operator = LAO target_country = COM ap_factory_reset_status = 5 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1611579014-M1611579014-FFFFFFFFFFF-U1611592090-0 is_one_binary_dual_plan = 0 memory_size = 30670848 memory_id = FMAEE8 bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; LAF protocol error. Downgrade the phone firmware. Hello, I am LAF. Nice to meet you. Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; This phone may require firmware downgrade !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : C:\Users\Peti\Downloads\SEC_BKP_LG K20_NA.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 3 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: NA IMEI B: NA IMEI C: NA WiFi ADDR: 00:00:00:00:00:00 BT ADDR: 00:00:00:00:00:00 LOCK STATUS: Done; Working; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:08:40 Is it possible to refund credit ? ID:5CF311F5 Thanks! Regards! |
