12-16-2019, 23:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Worlds first!!! alcatel 5048a unlock done...king furious Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM18)) Preparing to start flash mode; Preparing to open COM18 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 8b0f3401c02069e015b3087c197d0b3e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x52000115 0x4D343650 0xAC8C0142 0x899615C2 [SIZE=0xE91000000] IMEI1 [OTP 0001]: 358343-10-033142-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5048A-2B5CBS11 USRDATA INFO: 0x17D000000 SIZE: 0xD0ECFBE00 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 |
The Following User Says Thank You to ziggywong0305 For This Useful Post: |
12-16-2019, 23:45 | #2 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Thanks to the boss hack3r2k,for your hard work and continued dedication to this tool and also making it number 1 choice for unlocking and always worlds first!!!! |
The Following 6 Users Say Thank You to ziggywong0305 For This Useful Post: |
12-24-2019, 16:06 | #3 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Saint-Marc, Haiti
Member: 992258 Status: Offline Thanks Meter: 21 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM30)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM30 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 58d4ca2541493dfdbedb1789a7f747b2 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x52000115 0x4D343650 0xDE8C0142 0x899675C2 [SIZE=0xE91000000] IMEI1 [OTP 0001]: 358343-10-xxxxxxxx IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5048A-2A5CBS11 USRDATA INFO: 0x17D000000 SIZE: 0xD0ECFBE00 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_24_12_2019_10_03_47.txt |
12-26-2019, 08:52 | #5 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Quote:
You must use latest update https://www.furiousgold.com/en/news/otsmart-86 and select 5048 ! Simple as that Br | |
11-27-2020, 19:06 | #6 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Santiago de Cuba
Member: 2510340 Status: Offline Thanks Meter: 74 | 2019 security tested ok Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM42)) (Driver version: 2.0.1136.0) Preparing to start flash mode; Preparing to open COM42 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 6231e9f35697ccbb64ca6a5b85a8a3a7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x52000115 0x4D343650 0x5E830142 0x97861CA8 [SIZE=0xE91000000] IMEI1 [OTP 0001]: 35xxxxxxxxxxxxx IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5048A-2A5CBS11 USRDATA INFO: 0x17D000000 SIZE: 0xD0ECFBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 |
