10-24-2007, 15:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | LG KG 275 help help !!!!!!! it says simcard erorr .... when i entre codes and press send key it does not work... It just says emegency call only.. i have try it several times and i got the same result.. please help me ..thanks to you all |
10-24-2007, 17:22 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: paris Age: 44
Member: 24284 Status: Offline Thanks Meter: 56 | DO LIKE mamirza SAY it work Use wrong sim and try again. to unlock kg275 you must do this: 1-put the wrong sim card 2-compose the unlock code 3-press call button |
11-04-2007, 18:42 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | i got a big problem with kg275 i used com1 and usb/com with Fgold-014 and ufs kg800 cable and full charged batt but all time i got Press power on ! Starting communication ... Platform: E-Gold Lite ... Error ... ! Time needed - 00:01:20 even when i try with read flash |
11-04-2007, 18:50 | #7 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: With You In Mind
Member: 300540 Status: Offline Thanks Meter: 103 | Quote:
Update dongle with PACK 1. Read FAQ ! And you must use rj45 kg800 cable and not usb one. BR. | |
11-04-2007, 19:10 | #8 (permalink) | |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Quote:
Code: Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 357445016150563 UNLOCK CODE: 40135961 Data saved to KE_EEP_19.02.00_04.11.2007_DUMP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:59 i try to enter but phone say emergency call only my unlock code is 40135961 so i've try 40135961#*# with or w/o sim but still locked phone version V10b KG275P16FL | |
11-05-2007, 10:08 | #10 (permalink) | |
flashed phone with all versions of mg160 but no luck to enter code even turn back to riginal version from support SAME!!! | |
11-05-2007, 10:23 | #11 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | ahhhhhhhhhhhhh even code is not accepted reflash phone with 1st version then it will unlock phone is working now ---- thanks for help |
06-28-2008, 12:23 | #13 (permalink) |
Insane Poster Join Date: Jul 2003 Location: France Age: 48
Member: 33714 Status: Offline Thanks Meter: 0 | hi mekki , you need to flash your phone with ( KG275P16-AFR-V10a-***-XX-APR-02-2007 ) after flashing restart the phone ,it will ask for code , sooo you know the rest Good luck |
HELP unlouck lg kg 275 | nejm | Infinity-Box | 1 | 08-23-2008 07:27 |
Help lg kg 275 | karikari | FuriousGold | 2 | 03-14-2008 11:23 |
lg kg 275 | toto05 | FuriousGold | 5 | 11-25-2007 19:02 |
LG KG 275 help help !!!!!!! | karikari | Infinity-Box | 2 | 10-24-2007 19:04 |
please need help to flash and unlock LG KG 275 | sof940 | HWK | 0 | 10-09-2007 04:52 |
