06-16-2021, 21:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Guatemala
Member: 576278 Status: Offline Thanks Meter: 33 | unlock k52 LM-K520HM successful first world Engine version 1.0.0.5327 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM45 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 85 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_11 download_sw_version = device_sw_version = K520HM10d secure_device = S laf_sw_version = 1.1 device_factory_version = LMK520HMAT-01-V10a-704-01-SEP-02-2020+0 device_factory_out_version = LMK520HMAT-00-V10a-704-01-SEP-02-2020+0 pid = 13PEDD17YKYH00J4X imei = 356634111259988 model_name = LM-K520HM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1599095117-M1599095117-FFFFFFFFFFF-U1599103656-0 is_one_binary_dual_plan = 0 memory_size = 122159104 memory_id = DH6DAB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : D:\Furious\Pack 6\OTSmart_v1.0.0.5327_JO_Edition\SEC_BKP_LG LM-K520EMW_356634111259988.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 2 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 356634-11-125998-8 IMEI B: 350305-26-000000-1 IMEI C: 350305-26-000000-1 WiFi ADDR: 48:90:2F:CA:CD:F7 BT ADDR: 48:90:2F:5A:64:10 LOCK STATUS: 1 0 0 0 Unlock codes: NCK: 0000000000000000 NSCK: 0000000000000000 SPCK: 0000000000000000 CPCK: 0000000000000000 SIMCK: 0000000000000000 Enter the codes without a sim by using *#*#7465625#*#* Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Phone unlocked; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:06:18 Log file saved to: LOG_16_06_2021_13_42_25.txt |
The Following 3 Users Say Thank You to Neron-Cell For This Useful Post: |
