06-11-2021, 14:57 | #1 (permalink) |
Banned Join Date: Jun 2008 Location: Algérie
Member: 784101 Status: Offline Sonork: 92737 Thanks Meter: 39 | LG-LM-K500MM, 1 Multipurpose credit gone but device still locked,please help Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5327 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM23 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 76 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = K500MM10o secure_device = S laf_sw_version = 1.1 device_factory_version = LMK500MMAT-02-V10o-310-160-MAR-26-2021-ARB00+0 device_factory_out_version = LMK500MMAT-00-V10o-310-160-MAR-26-2021-ARB00+0 pid = WI18S210127017898 imei = 355041617846329 model_name = LM-K500MM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1616714309-M1616714309-FFFFFFFFFFF-U1616717261-0 is_one_binary_dual_plan = 0 memory_size = 61087744 memory_id = GX6BAB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; This phone may require firmware downgrade !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : C:\Program Files (x86)\FURIOUS-GOLD\PACK6\OTSmart\SEC_BKP_LG LM-K500MM_NA.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: NA IMEI B: NA IMEI C: NA WiFi ADDR: 00:00:00:00:00:00 BT ADDR: 00:00:00:00:00:00 LOCK STATUS: Unlock codes: NCK: NSCK: SPCK: CPCK: SIMCK: Enter the codes without a sim by using *#*#7465625#*#* Done; ERROR: simlock_status Failed ! Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:09:14 Please help refund credit and advice correct procedure to go with in order to get the device fully unlocked! Find here My Device ID [SERIAL]: 11B77661 |
06-11-2021, 21:36 | #2 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Current software not supported firmware need to downgrade and then unlock will be successful....Downgrade software at your own risk u have been warned...... |
06-14-2021, 10:32 | #7 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Nairobi,Kenya
Member: 390521 Status: Offline Thanks Meter: 57 | You can downgrade the phone but be sure it will brick..The headache to revive it will make your ancestors not happy..been through that but eventually the phone was unlocked successfully. |
06-15-2021, 05:25 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
you only must downgarde laf_a and laf_b partitions for k500mm. Thats 100% safe and working Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
