lg lm-x525ha lost multipurpose credit phone still locked Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_633E&REV_0409) Preparing to start flash mode; Preparing to open COM92 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = USER battery_level = 85 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X525HA20q secure_device = S laf_sw_version = 1.1 device_factory_version = LMX525HAAT-32-V20a-704-01-NOV-04-2020+0 device_factory_out_version = LMX525HAAT-00-V20a-704-01-NOV-04-2020+0 pid = 9BEEAN67DSVX022Y3 imei = 355498102405401 model_name = LM-X525HA device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1604505780-M1604505780-FFFFFFFFFFF-U1604511760-0 is_one_binary_dual_plan = 0 memory_size = 122159104 memory_id = GP6BMB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Linux localhost 4.9.190 #1 SMP PREEMPT Wed Nov 4 13:09:37 -03 2020 armv7l Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; This phone may require firmware downgrade !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: Comport open failed ! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : C:\Users\barney\Downloads\OTSmart_v1.0.0.5188_SEC_ Edition\SEC_BKP_LG LM-X525HA_NA.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: NA IMEI B: NA IMEI C: NA WiFi ADDR: 00:00:00:00:00:00 BT ADDR: 00:00:00:00:00:00 LOCK STATUS: Unlock codes: NCK: NSCK: SPCK: CPCK: SIMCK: Enter the codes without a sim by using *#*#7465625#*#* Done; ERROR: simlock_status Failed ! Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:08:20 box username: FGBOX839 |
V20 must be downgrded. if you would use the latest version then you could see. Credit refunded Br;) |
