02-07-2021, 15:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | LG-M400DY Fail to reset Pattern lock [OTsmart] [SOLVED] Code: Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5193 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_????) Preparing to start flash mode; Preparing to open COM25 Opened; Authorising; Authorized; download_cable = 910K battery_level = 50 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = M40010h secure_device = N laf_sw_version = 1.1 device_factory_version = LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 device_factory_out_version = LGM400DYAT-00-V10h-GLOBAL-COM-APR-07-2017+0 pid = VS01S170519000643 imei = NA model_name = LG-M400DY device_build_type = U chipset_platform = mt6750 target_operator = GLOBAL target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1491548312-M1491548312-C1491555647-U1491555647-0 is_one_binary_dual_plan = 0 memory_size = 30535680 memory_id = QE13MB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 [0x00080000-0x00300000]-[PROINFO] [0x00380000-0x00480000]-[SPARE1] [0x00800000-0x00800000]-[MISC2] [0x01000000-0x00800000]-[FTM] [0x01800000-0x00500000]-[NVRAM] [0x01D00000-0x00300000]-[SPARE2] [0x02000000-0x00800000]-[PROTECT1] [0x02800000-0x00800000]-[PROTECT2] [0x03000000-0x00100000]-[LK] [0x03100000-0x00100000]-[LK2] [0x03200000-0x01C00000]-[LAF] [0x04E00000-0x00080000]-[PARA] [0x04E80000-0x01180000]-[BOOT] [0x06000000-0x01800000]-[RECOVERY] [0x07800000-0x01800000]-[RECOVERYBAK] [0x09000000-0x00800000]-[LOGO] [0x09800000-0x00800000]-[LO_BAK_GO] [0x0A000000-0x00A00000]-[EXPDB] [0x0AA00000-0x00600000]-[SPARE3] [0x0B000000-0x00800000]-[SECCFG] [0x0B800000-0x00800000]-[OEMKEYSTORE] [0x0C000000-0x00600000]-[SECRO] [0x0C600000-0x00800000]-[KEYSTORE] [0x0CE00000-0x00500000]-[TEE1] [0x0D300000-0x00500000]-[TEE2] [0x0D800000-0x00080000]-[EKSST] [0x0D880000-0x00080000]-[ENCRYPT] [0x0D900000-0x00800000]-[PERSIST_LG] [0x0E100000-0x01600000]-[MPT] [0x0F700000-0x00A00000]-[LGFOTA] [0x10100000-0x00100000]-[RCT] [0x10200000-0x03800000]-[FACTORY] [0x13A00000-0x00080000]-[EFUSE] [0x13A80000-0x00580000]-[SPARE4] [0x14000000-0x03000000]-[PERSIST] [0x17000000-0x00800000]-[NVCFG] [0x17800000-0x02000000]-[NVDATA] [0x19800000-0x02000000]-[METADATA] [0x1B800000-0x01800000]-[MD1IMG] [0x1D000000-0x00400000]-[MD1DSP] [0x1D400000-0x00300000]-[MD1ARM7] [0x1D700000-0x00500000]-[MD3IMG] [0x1DC00000-0x06400000]-[CUST] [0x24000000-0x00800000]-[FRP] [0x24800000-0xF1800000]-[SYSTEM] [0x116000000-0x20000000]-[CACHE] [0x136000000-0x01C00000]-[LAFBAK] [0x137C00000-0x00400000]-[SPARE5] [0x138000000-0x06800000]-[OP] [0x13E800000-0x264580000]-[USERDATA] [0x3A2D80000-0x01000000]-[FLASHINFO] ERROR: MOUNT FAILED; Time needed - 00:00:11 Log file saved to: LOG_7_02_2021_15_24_23.txt Last edited by temp_temp; 02-07-2021 at 15:41. |
02-07-2021, 15:40 | #2 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | [FIXED using FRP reset] Code: Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5193 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_????) Preparing to start flash mode; Preparing to open COM25 Opened; Authorising; Authorized; download_cable = 910K battery_level = 50 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = M40010h secure_device = N laf_sw_version = 1.1 device_factory_version = LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 device_factory_out_version = LGM400DYAT-00-V10h-GLOBAL-COM-APR-07-2017+0 pid = VS01S170519000643 imei = NA model_name = LG-M400DY device_build_type = U chipset_platform = mt6750 target_operator = GLOBAL target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1491548312-M1491548312-C1491555647-U1491555647-0 is_one_binary_dual_plan = 0 memory_size = 30535680 memory_id = QE13MB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Working; Erased FRP Done; Done; Done; Factory Reset Protection successfully removed ! Time needed - 00:00:25 Log file saved to: LOG_7_02_2021_15_37_25.txt |
02-07-2021, 17:27 | #6 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | Code: Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5193 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_????) Preparing to start flash mode; Preparing to open COM25 Opened; Authorising; Authorized; download_cable = 910K battery_level = 50 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = M40010h secure_device = N laf_sw_version = 1.1 device_factory_version = LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 device_factory_out_version = LGM400DYAT-00-V10h-GLOBAL-COM-APR-07-2017+0 pid = VS01S170519000643 imei = NA model_name = LG-M400DY device_build_type = U chipset_platform = mt6750 target_operator = GLOBAL target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1491548312-M1491548312-C1491555647-U1491555647-0 is_one_binary_dual_plan = 0 memory_size = 30535680 memory_id = QE13MB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Working; Getting security info; Setting secure mode; Done; Done; Wait; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_????) Preparing to start flash mode; Preparing to open COM25 Done; Opened; Authorising; Authorized; Setting secure mode; Done; Erasing; Wait; Done; Factory Reset Protection successfully removed ! Setting secure mode; Done; Time needed - 00:00:37 Log file saved to: LOG_7_02_2021_17_26_45.txt thx for fast replay |
