01-17-2021, 16:02 | #1 (permalink) |
Registered User Join Date: May 2009 Location: BONOUA - Ivory Coast
Member: 1040340 Status: Offline Thanks Meter: 58 | Mrd-lx1f pin code not work log: [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM26)) (Driver version: 2.0.1136.0) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: a48b30490463e3f1126ea03137f33ab4 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: MTgwN0Y4MDc0MzFEQ0E1RTcyMEY5QjNCQkQ0RERBNDk= HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x4C5B0142 0x3596D7F2 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Erasing Anti-theft / Privacy Lock; Time needed - 00:00:00 |
01-18-2021, 14:50 | #3 (permalink) |
Member: 1040340 Status: Offline Thanks Meter: 58 | [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM26)) (Driver version: 2.0.1136.0) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: a48b30490463e3f1126ea03137f33ab4 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: MTgwN0Y4MDc0MzFEQ0E1RTcyMEY5QjNCQkQ0RERBNDk= HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x4C5B0142 0x3596D7F2 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Erasing Anti-theft / Privacy Lock; Time needed - 00:00:00 Log file saved to: LOG_18_01_2021_13_43_20.txt Same phone ask password |
04-01-2021, 18:11 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | Quote:
hi some problem here Code: Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5201 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM45)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM45 Connecting; Downloading DA; Initializing; Rid: 8ae4b70e7f22d4904dbb5553eaa971dc Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: QzcxQTE0ODI5RUVBMUIzNTlDN0IxRUI1OTBBMTY3QjA= HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xE3EE0142 0xB316CE90 [SIZE=0x749400000] PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Erasing Anti-theft / Privacy Lock; Time needed - 00:00:00 Log file saved to: LOG_1_04_2021_18_43_17.txt https://file.io/PP1hh0bbPXr9 https://file.io/EBdx4Cv9BMwd | |
04-02-2021, 09:07 | #7 (permalink) | |
Member: 411207 Status: Offline Thanks Meter: 164 | files uploaded was deleted Quote:
https://gofile.io/d/8IEtuf https://gofile.io/d/SIkxwc | |
