06-21-2010, 07:14 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | HTC Unlock Starting cab upload; Preparing to install; Checking installed file; Library found; Read done with error: BIPO Done; Time needed - 00:00:09 If not supported any other way? WBR |
The Following User Says Thank You to msashami For This Useful Post: |
06-21-2010, 07:17 | #2 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1324470 Status: Offline Thanks Meter: 0 | When Unlocking, always use a unlock code – This method is the simplest and safest method to unlocking your phone. You can hook it up to servers; I would suggest code is if want to pay less (take the risk of trouble) on older models. New phones cannot be unlocked by software. I will suggest the website http://www.************.com/ which is doing good service .....you can approach this website |
06-21-2010, 07:31 | #3 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | this is log with OMAP: Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 0000000000000000000000000000000000 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - The network request is not supported. error initializing flash Trying alternative scanning method; Scanning 0 Scanning 1 Scanning 2 Scanning 3 Scanning 4 Scanning 5 Scanning 6 Scanning 7 Sorry, alternative scanning failed too Time needed - 00:00:24 |
06-21-2010, 07:39 | #4 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Through Imei Checking: Information on IMEI 355714018542107 Type Allocation Holder HTC Mobile Equipment Type HTC P4550 TyTN II GSM Implementation Phase 2/2+ IMEI Validity Assessment >|< Very likely Information on range assignment Est. Date of Range Issuance Around Q1 2007 Reporting Body British Approvals Board of Telecommunications (BABT) Primary Market Europe Legal Basis for Allocation EU R&TTE Directive Information on number format Full IMEI Presentation 355714-01-854210-7 Reporting Body Identifier 35 Type Allocation Code 35571401 Serial Number 854210 Check Digit 7 |
06-21-2010, 07:51 | #6 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Ok! thanks sir for answering! anyway i haved managed to unlock through Tunisian Unlocker (All_HTC). Free software It is TyTN II and is in supported list. if not supported then plz correct ur list. WBR |
06-21-2010, 07:55 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | You are wrong. Your model, Herm100 it's TyTN. The one we support it's TyTN II which it's also known as Kaiser 120 with Qualcomm and not Samsung CPU Regards Luskao |
06-21-2010, 08:40 | #10 (permalink) | |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Quote:
I have checked from numberingplans.com it is TyTN II how u can say that it is TyTN??? Also It is Hermes not Kiaser because i haved unlocked it with Hermes Soft and it is doen!!! WBR | |
06-21-2010, 08:43 | #11 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Well you said it's HERMES100, T8525, if you go to PDADB.net you can check that Herm100 it's not TyTN II You can tell us how it look like. TyTN or TyTN II? Kaiser has been tested many times. Hermes, never succed |
06-21-2010, 08:56 | #13 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Google it's your friend. Also,under the battery model info it's available, and when sync with Active sync info it's there too TyTNII Check the buttons And TyTN |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
06-21-2010, 09:02 | #14 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Sorry But ur TyTN picture is not being diplayed!!! and i have used google and now i believe that it is TyTN because it's keypad is white and TyTN has black keypad!! WBR |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
