01-29-2009, 02:47 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 381679 Status: Offline Thanks Meter: 0 | BlackBerry Dongle Can't Read Unlock Code For BlackBerry 8900 Reading info ... IMEI: 35948XXXXXXXXXX Calculating ... Unsupported simlock type ! Sorry but you must use slow method ! Time needed - 00:00:15 Already try with BlackBerry 8900 Vendor-ID 240, Vendor-ID 114 please advice |
01-29-2009, 03:30 | #2 (permalink) |
Freak Poster Join Date: May 2005 Age: 59
Member: 147105 Status: Offline Thanks Meter: 8 | BlackBerry Dongle Can't Read Unlock Code For BlackBerry 9000 I have the same problem with 9000 BOLD Searching for usb device ... Reading info ... IMEI: 355256XXXXXXXXXX Calculating ... Unsupported simlock type ! Sorry but you must use slow method ! Time needed - 00:00:06 when make slow method....nothing`????? |
01-29-2009, 10:26 | #5 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | WEll you may try by slow method. hack3r2k has much to do including studies also. Be patient as he will solve this issue BR Luskao |
The Following User Says Thank You to luskao For This Useful Post: |
06-10-2009, 15:58 | #9 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TOKYO JAPAN Age: 43
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks Meter: 444 | blackberry 9000 Searching for usb device ... Reading info ... IMEI: 355256xxxx Calculating ... Unsupported simlock type ! Sorry but you must use slow method ! Time needed - 00:00:07 i have tried many times with " sfi " files... still no result and then i try MFI Multiloader = REULT is success 100 %, what happen with furious gold ? any bugs there ?? |
06-11-2009, 07:24 | #11 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
so dont have sfi files on suport... | |
100%How to Enter Unlock Code for Blackberry 8900,9000, 9500, 9530 Storm | adnanali | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 6 | 07-22-2011 20:46 |
wany unlock code for blackberry 8900 | mobilemani | BlackBerry (RIM) | 8 | 02-19-2010 13:37 |
Need unlock code for BlackBerry 8900! | /FAISAL/ | BlackBerry (RIM) | 8 | 01-30-2010 07:55 |
FG can't read SPCK code for Alcatel C550 | said4 | FuriousGold | 11 | 05-17-2007 18:03 |
Panasonic GD87 new ver: can't read unlock Code | hamidtele | Panasonic | 5 | 09-12-2003 16:49 |
