02-15-2020, 13:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: south africa
Member: 1712315 Status: Offline Sonork: 100.1602299 Thanks Meter: 65 | Y5 2019 AMN-LX9 IMEI data not found Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM81)) (Driver version: 2.0.1136.0) Preparing to start flash mode; Preparing to open COM81 Connecting; Downloading DA; Initializing; Rid: c60b34fb7c8d00cc8664977e2e3430d3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x6FEC0142 0xE516F7C6 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Checking data; IMEI data not found; Time needed - 00:00:00 Log file saved to: LOG_15_02_2020_04_49_12.txt |
