01-29-2013, 13:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | Flashing alcatel 808 Make your handset power off, plug in the UART cable! Product: OT-808 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 356389036598610 Provider ID: 808X-2BRGUG5 Security information version: N/A Detect special firmware version! If the handset is reflashed with SIMFree version, it may not power on correctly! If so, you can try to repair the handset secure region with special golden file after flash process is done! Flash handset image failed! Error Code: 8025 Please double check the cable and handset connection! Try it again! |
