03-30-2021, 13:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: morocco Age: 43
Member: 2304612 Status: Offline Sonork: 100.1660906 Thanks Meter: 7 | PHone still locked lg K50 (Solved) Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5201 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM355 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 59 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X520EMW20l secure_device = S laf_sw_version = 1.1 device_factory_version = LMX520EMWAT-64-V20e-EEA-XX-DEC-29-2020+0 device_factory_out_version = LMX520EMWAT-00-V20e-EEA-XX-DEC-29-2020+0 pid = 014DAN66EX05007DG imei = 355471102251398 model_name = LM-X520EMW device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1609229391-M1609229391-FFFFFFFFFFF-U1609233780-0 is_one_binary_dual_plan = 0 memory_size = 61087744 memory_id = GX6BMB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; LAF protocol error. Downgrade the phone firmware. Hello, I am LAF. Nice to meet you. Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : D:\BOX\Furious\JG SECURITY\SEC_BKP_LG K50_355471102251398.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 355471-10-225139-8 IMEI B: 355471-10-225140-6 IMEI C: 350305-26-000000-1 WiFi ADDR: 7C:F3:1B:EF:3B:C3 BT ADDR: 7C:F3:1B:83:20:A0 LOCK STATUS: 4 6 0 0 Unlock codes: NCK: 0000000000000000 NSCK: 0000000000000000 SPCK: 0000000000000000 CPCK: 0000000000000000 SIMCK: 0000000000000000 Enter the codes without a sim by using *#*#7465625#*#* Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Phone unlocked; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:05:19 Log file saved to: LOG_30_03_2021_13_46_29.txt |
03-30-2021, 13:42 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
as long is a firmware before oct 2020 it will work. and i cant refund if you dont give the id. i cant guess it Br | |
03-30-2021, 19:50 | #11 (permalink) |
Member: 2304612 Status: Offline Sonork: 100.1660906 Thanks Meter: 7 | ALL done thanks more Sir Hacker3 aftar downgrade the firmware in date 20.06.2020 .The phone finally unlockd thanks brother and best Team Br |
The Following 2 Users Say Thank You to mobarik For This Useful Post: |
