Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 08-25-2008, 17:46   #1 (permalink)
Member: 10483
Thanks Meter: 23
Is it possible to change imei on ks20 or not ?
Hi,
I need to change imei on KS20 is it possible or not ?
Thks
Old 08-27-2008, 09:23   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Originally Posted by gsmnice View Post
Hi,
Thks
hi all..
is there anyway to change imei..? thanx alot..
Old 08-27-2008, 16:56   #3 (permalink)
Member: 675004
Thanks Meter: 3
IMEI is READ_ONLY_S and you can't write IMEI directly.
But it's possible to change IMEI if You will be follow next instructions;
1.You should have installed on PC QPST and NV Editor.
2. Connect NV Editor via QPST port to a device, read all of nv from mobile, than save it to a file .brt
3.Flash new ROM without restoring .nv2 with option "Erase EFS" enabled.
4. Open in NV Editor the saved .brt file and press Find, enter 550. It wil be IMEI, edit it in the right lower corner of window. You should edit the column Hex Value (IMEI is writted in little indian (from right to left) after the letter A.)
and then connect to the device and after a changing IMEI press download all actieve to mobile.
5.Soft reset device, connect LGDDP and restore .nv2 with the option "Reset darabase&contens" (NOT ERASE EFS!). Iou'll have new IMEI.
If you dun understand or can't make it, you can send me your .nv2 file, i can modify it for you.
Check your private msg for my email address
The Following User Says Thank You to raykisi For This Useful Post:
Old 08-28-2008, 09:38   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
great work sir.. thanx alot.. and what r u thinking about ku990 new sw..? they r not unlocking...
Old 07-14-2009, 13:49   #5 (permalink)
Member: 1074404
Hi,
can you edit one piece of information in nv2 file please. I need to change imei no. but i cant do it. no matter what do with it. i honestly followed your steps but i cant do it.
Pls. send me your email address to [email protected]. I will send you files and my imei no.
I have tried to pm you thru here, but failed....
please help!!!!
Thanks in advance....
Old 10-21-2012, 16:52   #6 (permalink)
..:::Gsm india:::..'s Avatar
Member: 380464
Thanks Meter: 141
357323-01-225237-X-unbranded
this my imei no plz give me nv2 file needed my phone imei 00000
Is it possible to Change IMEI for K800i or W850 using UB Fones_Clinic_Network Universalbox 4 08-02-2007 01:02
Is it possible to change Imei on V600? cheeky2 Motorola P2k 15 09-27-2004 17:30
Is it possible to change imei on sagem MYX5m, MYX3, X6... gsmnice ARM9 BASED M62 / M62+ 4 09-18-2003 12:50
Is it possible to Change IMEI on T300 gazt Sony Ericsson 7 06-06-2003 03:34
Is it possible to change imei on sony mobile as j70, z5... gsmnice Sony 7 04-16-2002 20:47
Page generated in 0.15328 seconds with 9 queries
