Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 01-11-2010, 12:14   #1 (permalink)
Rhyks's Avatar
Member: 243127
Thanks Meter: 35
How to use the New blackberry tool?
I have tried to unlock Blackberry 9530 with read option then, do job now the unit is on "No application linked" status and also tried Blackberry 8100 with the same procedure but the unit is now on "Jump Error 543" please do advice...thanks! I hope you can give the correct procedure on how to use this new software...thanks!
Old 01-11-2010, 12:15   #2 (permalink)
FTEAM_MODERATOR's Avatar
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
I think you have disabled fast code read, enable it
Old 01-11-2010, 16:10   #3 (permalink)
Rhyks's Avatar
Member: 243127
Thanks Meter: 35
In my second attempt I disable the fast code read but on my first attempt which is the Blackberry 9530 I am definitely did not enable the fast code read..Then on what way I can have a compatible SFI for the said unit during unlocking?...thanks1
Old 01-11-2010, 16:14   #4 (permalink)
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
You just need to connect phone and have FAST CODE READ enabled, no file needed
Old 01-12-2010, 03:09   #5 (permalink)
Rhyks's Avatar
Member: 243127
Thanks Meter: 35
Sir, during my read process of Blackberry 9530 it ask me a SFI file. Do I need to flash my phone with safe firmware as of my SFI?
Old 01-12-2010, 08:42   #6 (permalink)
Member: 1144248
Sonork: 100.1574721
Thanks Meter: 3,936
You don't need SFI, please check the functions, you ma have Fast code read in disable and you must enable it
Regards
Furious Support
Old 01-13-2010, 07:10   #7 (permalink)
Rhyks's Avatar
Member: 243127
Thanks Meter: 35
thanks! Everything is now working...
The Following User Says Thank You to Rhyks For This Useful Post:
How to use the DIV2UFS to convert the flash file for T610? hooi76 UFS2 + UFS3-Tornadoflasher 0 02-20-2008 11:58
Zulea, How to use the EE file read from the V802? testpoint SonyEricsson (USB-Smart) 0 09-26-2005 04:23
Sysol Tool v 3.0. How to use the the "Repair" function. doctormike TST Dongle 3 09-10-2005 04:51
Page generated in 0.20476 seconds with 9 queries
