..::Step by step Unlocking Instructions for Toshiba 803T,902T,903T,904T::.. 1.Use original USB cable,which goes together with phone or NEC N8 cable(same as for unlock Sharp GX15,GX25) 2.Start "TS803_usb-driver_setup.exe" from "USB Drivers" folder and install drivers for phone. WARNING : Drivers and software works only on Windows XP,Windows 2000. 3.Connect USB cable to phone and power ON phone.Wait until Windows will find phone and will finish drivers installing. 4.Go to "Start"-Settings"-"Control Panel"-"System"-"Hardware"-"Device Manager"-"Modems" and look what ComPort is selected for "Toshiba 803 modem" or for "VODAFONE 902T modem".For this do next: right click with mouse at "Toshiba 803 modem" or "VODAFONE 902T modem" - in the opened submnenu select "Properties" - in the "Properties" submenu select "Modem" 5.Start software and select same ComPort.Press "Connect" and when software will read phone info,press "Direct unlock". 6.WARNING : Software can't recognize phone if phone code is set,in this case phone writes on display "Phone lock".For working with software you need to dissable phone lock,try main code "9999" or ask phone's owner what phone code is set. BR, Ron2pet |
hi nice information man br hafiz tauseef |
Using RESET SECURITY AND SPC codes will be resetted by default to 0000. Br;) |
Thx realy goes to Biggest Sagem hero . Quote:
Regards the_frightener |
thanks man for the instructions |
but mine 904t is not working this way yy???? i installed driver succesfully it showz modem port but stil cant find fone y??? plz help me furious team thankx falak |
yes me too at sanyo....and 904 also modem query ok all shown at com 6 now i run he program click do job searching phone ...... time needed 00;00;00 sir.... just like that ................what is wrong ?? my fgbox at com port 1 at command (7) obex (8) what will i do ?????????? |
Br;) |
Software can't recognize phone if phone code is set ! How to use RESET SECURITY & SPC funtion on soft for reset fone code to 0000 ? |
Br;) |
BR., Denis |
problem below: (904T) Searching phone ... Model: TOSHIBA IMEI: 3584230xxxxxxx-x Working ... Please Wait ! SEC Code: 0000 but then show me need Toshiba DL driver ! but phone also unlock ok! |
Br;) |
will there be ever flashing to toshiba phones in the future? |
