08-27-2023, 13:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2022 Location: fsd Age: 23
Member: 3008540 Status: Offline Thanks Meter: 17 | Tcl t779w flashing error [SOLVED] i have used 2 different firmwares. logs Using library Brom_DLL_v7.2116.0 Engine version 1.0.0.6344 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM85)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM85 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 440c98d6377ba7c0520637328117596d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6833 [CA00, 00, 6833, 00] BB ID: QzZFQTBEQkFGNjRDQTA0MTRGQ0JCRjk2RTRDOUUzNTE= HW_STORAGE_UFS: 0x4C354D4B 0x31303039 0x422D4D44 0x00343234 [SIZE=0x1DCB800000] IMEI1 [OTP 0001]: 016099-00-080654-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: T779W-2ATBUS11 USRDATA INFO: 0x24D000000 SIZE: 0x1B7CFF8000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Loading the file ... Cfg done ... Formatting file system now... Formatting file system now... Done; Formatting MISC partition now... Done; Formatting PARA partition now... Done; Formatting FRP partition now... Done; Formatting NVCFG partition now... Done; Formatting NVDATA partition now... Done; Formatting VBMETA_A partition now... Done; Formatting VBMETA_SYSTEM_A partition now... Done; Formatting VBMETA_VENDOR_A partition now... Done; Formatting VBMETA_B partition now... Done; Formatting VBMETA_SYSTEM_B partition now... Done; Formatting VBMETA_VENDOR_B partition now... Done; Formatting METADATA partition now... Done; Formatting OEMPERSIST partition now... Done; Formatting OEMBIN partition now... Done; Formatting SECCFG partition now... Done; Formatting MD1IMG_A partition now... Done; Formatting SPMFW_A partition now... Done; Formatting SCP_A partition now... Done; Formatting SSPM_A partition now... Done; Formatting GZ_A partition now... Done; Formatting LK_A partition now... Done; Formatting BOOT_A partition now... Done; Formatting VENDOR_BOOT_A partition now... Done; Formatting DTBO_A partition now... Done; Formatting TEE_A partition now... Done; Formatting SWVERSION partition now... Done; Formatting BOOT_PARA partition now... Done; Formatting SMART partition now... Done; Formatting MD1IMG_B partition now... Done; Formatting SPMFW_B partition now... Done; Formatting SCP_B partition now... Done; Formatting SSPM_B partition now... Done; Formatting GZ_B partition now... Done; Formatting LK_B partition now... Done; Formatting BOOT_B partition now... Done; Formatting VENDOR_BOOT_B partition now... Done; Formatting DTBO_B partition now... Done; Formatting TEE_B partition now... Done; Formatting SUPER partition now... Formatting SUPER partition now... Done; Formatting ODM_A partition now... Done; Formatting PRODUCT_A partition now... Formatting PRODUCT_A partition now... Done; Formatting VENDOR_A partition now... Formatting VENDOR_A partition now... Done; Formatting SYSTEM_A partition now... Formatting SYSTEM_A partition now... Done; Formatting SYSTEM_B partition now... Formatting SYSTEM_B partition now... Done; Formatting OEM_A partition now... Formatting OEM_A partition now... Done; Formatting USERDATA partition now... Formatting USERDATA partition now... Done; Downloading images... Done; Downloading bootloader... ERROR: STATUS_SEC_PL_VFY_FAIL Time needed - 00:04:24 Log file saved to: LOG_27_08_2023_17_15_51.txt |
08-27-2023, 13:21 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Quote:
Install version 3.1504 for the drivers and retry. Also are you sure about the model? Which files you tried!? Br Sent from my iPhone using Tapatalk Pro | |
08-27-2023, 13:29 | #3 (permalink) | |
08-28-2023, 07:39 | #7 (permalink) | |
779WV is not the same as t779W . Its different. And i didnt ask which drievrs you have installed. I told you what you must have installed. And for further help you must provide your box id Br | |
08-30-2023, 15:36 | #13 (permalink) |
Member: 3008540 Status: Offline Thanks Meter: 17 | Using library Brom_DLL_v7.2116.0 Engine version 1.0.0.6344 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM6)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM6 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 440c98d6377ba7c0520637328117596d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6833 [CA00, 00, 6833, 00] BB ID: QzZFQTBEQkFGNjRDQTA0MTRGQ0JCRjk2RTRDOUUzNTE= HW_STORAGE_UFS: 0x4C354D4B 0x31303039 0x422D4D44 0x00343234 [SIZE=0x1DCB800000] IMEI1 [OTP 0001]: 016099-00-098524-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: T779W-2ATBUS11 USRDATA INFO: 0x24D000000 SIZE: 0x1B7CFF8000 Loading the file ... Cfg done ... Formatting file system now... Formatting file system now... Done; Formatting MISC partition now... Done; Formatting PARA partition now... Done; Formatting FRP partition now... Done; Formatting NVCFG partition now... Done; Formatting NVDATA partition now... Done; Formatting VBMETA_A partition now... Done; Formatting VBMETA_SYSTEM_A partition now... Done; Formatting VBMETA_VENDOR_A partition now... Done; Formatting VBMETA_B partition now... Done; Formatting VBMETA_SYSTEM_B partition now... Done; Formatting VBMETA_VENDOR_B partition now... Done; Formatting METADATA partition now... Done; Formatting OEMPERSIST partition now... Done; Formatting OEMBIN partition now... Done; Formatting SECCFG partition now... Done; Formatting MD1IMG_A partition now... Done; Formatting SPMFW_A partition now... Done; Formatting SCP_A partition now... Done; Formatting SSPM_A partition now... Done; Formatting GZ_A partition now... Done; Formatting LK_A partition now... Done; Formatting BOOT_A partition now... Done; Formatting VENDOR_BOOT_A partition now... Done; Formatting DTBO_A partition now... Done; Formatting TEE_A partition now... Done; Formatting SWVERSION partition now... Done; Formatting BOOT_PARA partition now... Done; Formatting SMART partition now... Done; Formatting MD1IMG_B partition now... Done; Formatting SPMFW_B partition now... Done; Formatting SCP_B partition now... Done; Formatting SSPM_B partition now... Done; Formatting GZ_B partition now... Done; Formatting LK_B partition now... Done; Formatting BOOT_B partition now... Done; Formatting VENDOR_BOOT_B partition now... Done; Formatting DTBO_B partition now... Done; Formatting TEE_B partition now... Done; Formatting SUPER partition now... Formatting SUPER partition now... Done; Formatting USERDATA partition now... Formatting USERDATA partition now... Done; Downloading images... Done; Downloading bootloader... ERROR: STATUS_DOWNLOAD_EXCEPTION SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Time needed - 00:06:15 Log file saved to: LOG_30_08_2023_19_23_38.txt |
