11-12-2022, 09:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Tecno spark 5 air failed to unlock!! Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5950 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM4)) (Driver version: 2.0.0.0) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 33fa11ab45032553e83f7694461b4e08 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x1310033E 0xA3A78931 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xF5000000 SIZE: 0x64F0FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_12_11_2022_10_27_46.txt Is there any solution for this model |
11-24-2022, 16:23 | #3 (permalink) |
Member: 132881 Status: Offline Thanks Meter: 105 | ****************************/file/puduh...b4e08.osp/file Please find attched the link to the requested file |
