u3300 not unlocking [SOLVING] Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Error ... ! Time needed - 00:00:34 some time other error Step by step how to unlock 1 phone must without battery 2 cut cable and take green pins &solder like in pic 3 holding * + # + on and put cable to phone 4 now show bootloader mode 5 insstalle correct driver 6 select seconde port 7 easy to clic dojob wait finish Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Data not found ! Contact support ! Error ... ! Time needed - 00:00:34 Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Data not found ! Contact support ! Error ... ! Time needed - 00:00:34 wher is mistake plz tell me thanx |
Theres no mistake. Eitehr someone before you tried to unlock it using other sw and damaged phone eitehr theres some newer/old sw version. Contact me on ICQ to solve pb. Br;) |
hello can u help to unlock u3300 i use v810 cable i solder the wire in green and solder in testpoint lik in pictur hold *+0+# and conect the cable to phone pc ask to drivers i tray to install from drivers pin 1009-715 but this driver not accepted .plz help me to install the drivers |
problem solved phone unlocked i installed the drivers from support mtv3.5 after that phone is reconised in flash mode well ,this is the lik for the driver : http://www.furious-gold.com/download.php?file_id=6480 |
Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Data not found ! Contact support ! Error ... ! Time needed - 06:22:41 |
I unlocked 3 pieces of Huawei U3300 with original usb cable (which comes with phone) without any problem. |
Contact me monday on icq ! Br;) |
