Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 10-09-2021, 13:01   #1 (permalink)
Member: 2502646
Sonork: 100.1581304
Thanks Meter: 34
Alcatel 5030d cant unlock allways server error
Connect timed out.
ERROR: Simlock set error !
Log file saved to: LOG_9_10_2021_12_51_44.txt
Time needed - 00:01:14
Searching phone;
For an successful connection do the following:
1. Power on the phone and power it off
2. Keep pressed firmly volume DOWN key
3. Insert the usb cable inside the phone while keeping pressed volume DOWN
Phone detected (@oem51.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.135)
Preparing to sync;
Port opened [COM47];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2019, FuriouSTeaM
Starting FDL2;
FDL2 sent;
Starting auth;
memory_type: IF_TYPE_MMC
dev_no: 0
part_type: PART_TYPE_UNKNOWN
vendor: Man 000088 Snr 2f412224
product: SLD32G
revision: 5.5
memory_size: 28.9 GB
HW IMEI : 000000-00-000000-0
PHONE INFO: NONE
PHONE ID: MDYxMWNlMGMwMDkxMjkyMw==
BT ADDR: NONE
SW IMEI[0]: 354828-11-XXXXXX
SW IMEI[1]: 354828-11-XXXXXX
SW IMEI[2]: 867400-02-XXXXXX
SW IMEI[3]: 867400-02-XXXXXX
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_354828-11-654869-0_98550000_9_10_2021_12_59_51.spd
Gathering security data;
Security check result: 0
Connecting to server;
ALLWAYS SERVER ERRORS PLS HELP ME HACK
Old 10-11-2021, 08:10   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,568
Hi,
Just retry. Probably server busy at the time you tried
Page generated in 0.13777 seconds with 8 queries
