02-04-2022, 01:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Poland Age: 42
Member: 19041 Status: Offline Thanks Meter: 23 | K500mm unlock done but stil locked Engine version 1.0.0.5479 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_633E&REV_0409) Preparing to start flash mode; Preparing to open COM446 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = USER battery_level = 100 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = K500MM10p secure_device = S laf_sw_version = 1.1 device_factory_version = LMK500MMAT-02-V10p-310-160-JUN-02-2021-ARB00+0 device_factory_out_version = LMK500MMAT-00-V10p-310-160-JUN-02-2021-ARB00+0 pid = WI06S210407029027 imei = 352411431533788 model_name = LM-K500MM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1622620693-M1622620693-FFFFFFFFFFF-U1622623360-0 is_one_binary_dual_plan = 0 memory_size = 61087744 memory_id = hB8aP> bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; This phone may require firmware downgrade !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : F:\instalki\FG\03.04.14\pack6\OTSmart_v1.0.0.5479_ JO_Edition\beckup\SEC_BKP_LG LM-K500MM_NA.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 10 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: NA IMEI B: NA IMEI C: NA WiFi ADDR: 00:00:00:00:00:00 BT ADDR: 00:00:00:00:00:00 LOCK STATUS: Unlock codes: NCK: NSCK: SPCK: CPCK: SIMCK: Enter the codes without a sim by using *#*#7465625#*#* Done; ERROR: simlock_status Failed ! Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:07:07 Log file saved to: LOG_4_02_2022_01_07_43.txt |
02-05-2022, 09:02 | #2 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | please use search next time we said 1000 times these firmware need to be downgraded post your box ID for refund |
02-05-2022, 11:07 | #3 (permalink) |
Member: 19041 Status: Offline Thanks Meter: 23 | My box id 21B2B833 Sorry but when I was looking for descriptions there were no descriptions about non-working software. My suggestion write a post from the oprogeamowan schedule and pin it permanently . |
02-09-2022, 16:56 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Problem with this that is hit and miss. for some models some variants from the same month work for some they dont. credit refunded Br | |
