02-26-2011, 15:58 | #1 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | VDF 246 unlocking problem I'm using FG USB Dongle and Profilic 2303 or FTDI Cable, both with 5V output. Cables are soldered directly to phones PCB. The problem is, that I always get this error: Quote:
THX! Regards Chris | |
02-27-2011, 10:11 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | What pinout you used? I have same problem at begining..finaly i succes unlock that phone using pinout from Hack after 1 day of testing! |
The Following User Says Thank You to djdansmart For This Useful Post: |
03-01-2011, 20:56 | #3 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | Finally I unlocked the first 246. As .:hack3r2k:. said, Pinouts from SagDD are not working on German phones, who knows why... And that was my prob. I unlocked the 246 with pinout from Vodafone.pdf But with my GS101 cable it is not working. The cable is working fine for GS101. Can the Resistor be the problem? I have got 150k R inside and not 130k as at the shematics. But for GS101 it is working fine. |
03-01-2011, 21:44 | #5 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | Right, it is not difficult. But via cable it is much more easier, faster, saver and cleaner. So there is no reason to prefer unlock via testpoints |
03-01-2011, 22:20 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
All possible help we offered here http://forum.gsmhosting.com/vbb/6871509-post2.html Br | |
03-01-2011, 22:46 | #7 (permalink) | |
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
I also read something about changing RX and TX from GS101 cable, but can't find anything inside the sticky? And you said THX for a posting, where it was posted. Or is THX only related to the picture of the mod of the box? | |
03-02-2011, 06:55 | #8 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 438551 Status: Offline Thanks Meter: 36 | Quote:
But in case with your phone the correct way is to use pinout from Vodafone.pdf , because it seems cable way there is not work. Br | |
03-02-2011, 12:41 | #9 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | It doesn't matter if we speak about RX or TX if we only speak about crossing RX/TX from GS101 cable! But how can it be possible that cable solution will work at one phone and with others not?! |
03-02-2011, 16:16 | #10 (permalink) | |
Concerning your question, the reason could be different SW or HW releases or some HW components fault , after tries to connect vdf246 using nokia usb cable for example. Br | |
03-12-2011, 22:48 | #11 (permalink) | |
Member: 41076 Status: Offline Thanks Meter: 53 | I still haven't solved my problem! If I solder the cable directly to the PCB every thing is ok, see the attached log. But with my GS101 cable I don't get any connection. Only sometimes I get connection but then I also get the error you can read in my first post. I also tried to remove the 5V from USB and to attach my external, adjustable power supply. With this I tried it with 3,3V and Battery and also with the normal 5V w/o battery procedure. Everytime the same! @.:hack3r2k:. You already told us, that the 246 from Germany is a littlebit diffrent and that also SagemDD pinout is not working. But have you ever tested to unlock a 246 via micro usb cable? Is the resistor, which is inside GS101 cable, important for VDF 246?? THX! Regards Chris Quote:
03-12-2011, 22:56 | #12 (permalink) |
Freak Poster Join Date: Oct 2007 Location: ALGERIA Age: 45
Member: 600493 Status: Offline Sonork: 0550106737 Thanks Meter: 39 | Good morning sir can u poste a good and corecte pinout for this vodafone i have sam probleme i cant conecte this phone thank u adavnce |
03-15-2011, 09:24 | #13 (permalink) | |
Hi, Yeah we tried but on german pcb never worked via cable Br | |
03-15-2011, 17:11 | #14 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | Hi! You never worked with it means you never get it working on that phone, right? That sounds like a terrible unlock for a very cheap phone Regards Chris |
03-15-2011, 17:31 | #15 (permalink) | |
Br | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
