04-10-2021, 10:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Vivo 1820 IMXX Repair Problem !! Old version say repair done but not change Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM4)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: e17e46592f7d5b80477a18476e1463c4 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x63190142 0x6F37B3D2 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x132800000 SIZE: 0x6118FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Checking data; NVRAM integrity check passed; Formatting NVDATA partition now... Done; IMEI repaired; Remove battery and cable; Time needed - 00:00:13 Log file saved to: LOG_10_04_2021_10_53_48.txt New version cannot perform the task. Here is Protect 1 & another data. |
