08-07-2013, 08:51 | #2 (permalink) |
Freak Poster Join Date: Jul 2012 Location: hole
Member: 1784040 Status: Offline Thanks Meter: 32 | After i follow these link http://forum.gsmhosting.com/vbb/f272...nlock-1651185/ set up to windiag phone was detected like logs below: UNKNOWN MODEL; CONTACT SUPPORT ! Error ... ! Time needed - 00:00:00 set up to win diag phone detected but check the logs below: Software engine version: 1.0.0.8743 Searching phone ... |
08-07-2013, 08:54 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Did you follow this instructions? 1. POWER ON THE PHONE WITHOUT USB CABLE ATTACHED. 2. IN CALL WINDOW INPUT ##634# AND CLICK “CALL” BUTTON. AFTER THIS, “MFG” APPLICATION WILL BE AVALIABLE IN THE LIST OF APPLICATION. 3. EXECUTE MFG AND INPUT PASSWORD 277634#*# – YOU WILL ENTER ENGINEER MENU. 4. GO TO ENGINEER MENU –> PORT SETTINGS –> USB SWITCHING AND SELECT “QC COMPOSITE”. 5. AFTER REBOOTING, CONNECT THE CABLE AND INSTALL DRIVERS. [LGUnitedMobileDriver_S498MA22_WHQL_ML_Ver_2.2.exe ON SUPPORT] |
08-07-2013, 09:08 | #4 (permalink) | |
Member: 1784040 Status: Offline Thanks Meter: 32 | Quote:
heres the logs below after windiag enabled: Software engine version: 1.0.0.8743 Searching phone ... UNKNOWN MODEL; CONTACT SUPPORT ! Error ... ! Time needed - 00:00:00 | |
