09-15-2022, 10:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | WIKO U316AT unlocked but call not connecting please any solution Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5943 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) or insert the USB cable in the powered off phone while keeping volume down+up pressed) Phone detected (MediaTek USB Port (COM124)) Preparing to start meta mode; Disabling watchdog timer; Done; Exploited; Sec code uploaded; Executed; Vodka time; Ready to party; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-r0.mp1-V8.107.1_tinno.sh.r0mp1.k61v1.64.bsp_P40 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V166.P15 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 860107-05-266782-3 IMEI 2: 000000-00-000000-0 Checking server support license; Checking sml; OK; Checking sml ext; OK; Checking nonce; Checking unlock_code; Checking sign; Calculating; Ok; Phone unlocked; Remove battery and cable; If the phone is still locked after the process then go to Settings->System->System updates->UICC unlock (be sure the phone is connected to wifi) Time needed - 00:00:39 |
