12-08-2016, 13:04 | #3 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1404722 Status: Offline Thanks Meter: 46 | i have readed it as telenor r60.here is full dump and nv. http://pc.cd/zCLotalK |
12-09-2016, 09:39 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Quote:
Simply do SIM_LOCK remove and will be unlocked ! Br | |
12-09-2016, 09:57 | #5 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | If the phone is still locked write this patched flash. https://forum.gsmhosting.com/vbb/****************************/?2ws3sn8i3mubvl3 Br |
12-09-2016, 11:01 | #6 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453225 Status: Offline Sonork: l Thanks Meter: 31 | telenor xt50 unlock OK!!!!!!!!!! Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem172.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM64]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 76:8D:08:45:2E:7E SW IMEI[0]: SW IMEI[1]: SW IMEI[2]: SW IMEI[3]: SIMLOCK FLAG: ON FIXED NV BASE: 303B8000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_9_12_2016_10_50_49.txt Time needed - 00:01:48 |
12-09-2016, 13:36 | #7 (permalink) | |
Member: 1404722 Status: Offline Thanks Meter: 46 | Quote:
Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM35]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 87B:08:15:27:EE SW IMEI[0]: 866790-02-293746-9 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 303B8000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_9_12_2016_13_31_41.txt Time needed - 00:02:02 now phone is unlocked. | |
The Following User Says Thank You to alexanderkrisz For This Useful Post: |
