02-24-2022, 16:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | ZTE Blade A31 Lite Security Repaired Phone was security damaged and Locked. After unlock and imei Repair, phone now working correctly need 2 logs Code: Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem532.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM73]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W20.47.1_P22_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.47.1_P22 HW Version: sc9832e_modem 11-10-2021 11:21:25 Build number: GEN_EU_P932F21V1.0.0B11 Friendly Name: QzQxRjhBRTg4QzdFMUIxRDhFMTkyRDBFMzIxQ0RDRjlERTVDRDFDMA== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 868096-01-xxxxx-1 SW IMEI[1]: 868096-01-xxxxx-2 SW IMEI[2]: 867400-02-xxxxx-8 SW IMEI[3]: 867400-02-xxxxx-6 SIMLOCK FLAG: OFF BKP saved to : BKP_000000-00-000000-0_868096-01-xxxxxx-1_00000000_24_02_2022_09_56_44.spd SIM_LOCK TYPE: 0 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: RjYyRjFFQkE2MzBCNEJFNDkyQjU2QkVGQzEzQTY3MjA= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Done; IMEI[0] repaired; Remove battery and cable; Log file saved to: LOG_24_02_2022_09_57_08.txt Time needed - 00:00:26 |
The Following User Says Thank You to yurais For This Useful Post: |
