Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Blazer
Old 03-10-2006, 17:19   #1 (permalink)
Member: 175790
Version 8.4 crashes after splash screen
this is the error I get:
AppName: blazer84.exe AppVer: 0.0.0.0 ModName: blazer84.exe
ModVer: 0.0.0.0 Offset: 000b0fdd
Does it even on a clean boot!
Any ideas?
Old 03-10-2006, 17:42   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
if you work under windows xp
just change compatibility of the software to "windows98" and it will work
br
<= The_Gorr =>
Any ideas?
Old 03-10-2006, 20:27   #3 (permalink)
Member: 175790
Thanx for the reply...after running in compatability mode it does not crash but, now I'm getting box not found Version 8.3 finds the box just fine.
Old 03-11-2006, 10:09   #4 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 14,047
Same me ...any Help in that ....
Old 03-11-2006, 19:32   #5 (permalink)
Member: 175790
Just some info for any possible help; I'm running Windows XP SP2 with .NET 1.1 and all up to date hotfixes
Old 03-12-2006, 00:16   #6 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
blazer 8.4 have crash problem on xp sp2 only, because of new themida.
we will put another version to fix this.
sorry for any inconvenience.
br
Old 03-12-2006, 09:31   #7 (permalink)
Member: 95960
Sonork: 100.1574721
Thanks then ...we are waitting Please do this as soon as possible
Old 03-12-2006, 09:53   #8 (permalink)
thehelmut's Avatar
Member: 45247
Thanks Meter: 49
same error here . waiting for solution.
LG B2050 "not found" problem u can fix too ?
Old 03-12-2006, 22:40   #9 (permalink)
Member: 65465
hi
i have had no preoblems with using v8.4 on xp pro sp2 as long as i`m using userport it all appears to run fine without using win98 compatability mode hope this helps
Old 03-13-2006, 10:48   #10 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
open A cable and make a link beetwen pin 12 and 19.
it will connect for sure.
br
Old 03-13-2006, 11:58   #11 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
we have detected a bug in version 8.4 please download version 8.4a
br
Old 03-13-2006, 21:23   #12 (permalink)
thehelmut's Avatar
Member: 45247
Thanks Meter: 49
now i works . muchas gracias !
b2050 :
84a + cable A modified + adapter = unlocked
another question : is modified cable still working for the other "A-cable phones " ?
Old 03-13-2006, 21:34   #13 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
b2050 :
you can let the cable modified.
it will work for other phones that require cable A.
br
Old 03-13-2006, 21:57   #14 (permalink)
thehelmut's Avatar
Member: 45247
Thanks Meter: 49
fine !
and my final question :
i flashed the b2050 with the flashfile from support site .
but branding is still there !
how to remove branding ? must i find a moded file ?
if yes : where to get
After Update my UB box to version 2.8.4.2498,can't get that version,why?? mantok Universalbox 5 11-30-2009 12:35
UST Pro version 8.30 crashes mcecaro UST Pro II 14 11-16-2008 19:59
T230 4 locks closed after div 8.4!!! .:SkiR:. Sony Ericsson 4 01-07-2004 09:32
Where can i download DIV, Version 8.4 bobby8850 Sony Ericsson 3 12-31-2003 22:14
T68i 4 lock's closed after CLEAR SP LOCKS DIV 8.4 Abdulgsm Sony Ericsson 10 10-19-2003 01:05
Page generated in 0.28871 seconds with 9 queries
