10-08-2004, 12:47 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: uk Age: 44
Member: 9990 Status: Offline Thanks Meter: 2 | *** FREE GIFTS HERE *** For Uni-Clip Users! This is a free gift for all Uni-Clip Customers! Sagem MY-C2 and MY-C2-2 Unlock Code calcualtor Download Here and contact us with your activation key, Uni-Clip serial number and your invoice number / reseller details Instructions ready shortly. [email protected] |
10-13-2004, 08:23 | #4 (permalink) |
Member: 9990 Status: Offline Thanks Meter: 2 | Yep, essojay can help you out or contact us on [email protected] |
10-22-2004, 01:02 | #7 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
Here is the start off instructions- more will be added later today along with full update instructions. When unlocking using Uni-Clip you must ensure that both the mobile phone battery and the batteries used in the clip are fully charged. Nokia DCT4 Handsets 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Connect the phone without a sim card or memory card to the correct cable and then connect the cable to the clip. 3) Turn uni clip on using the black switch on the side of the clip 4) Now power the phone on 5) Once the phone has powered and displays “insert sim card” press the button on the Uni-Clip once. 6) Uni clips lights will turn off, the phone will turn off and display “local mode” on the screen 7) One light will show on Uni-clip to indicate the unlocking process has started. 8) Then both lights will be on. The phone is now unlocked. Note - When using Nokia heads use the longest RJ45 > RJ45 connectors (approx 12"+) the smaller adaptors are for use with Universal adaptor Panasonic X60 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Make sure the phone is off without a sim card in. 3) Put the phone into test mode by holding down the # and * key and then the power button. You will see a faint back light on the phones screen. The phone is now in test mode. 4) Connect the X60 cable to the Uni-Clip and then to the phone 5) Turn Uni-Clip on using the black switch on the side of the clip 6) Press the Uni-Clip unlock button 7) The Uni-Clips lights will turn off, 8) One light will show on Uni-Clip to indicate the unlocking process has started. 9) Then both lights will be on to show the unlocking process is completed. The phones back light will go off. The phone is now unlocked. Sharp GX30, TM100 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Connect the cable to Uni-Clip 3) Make sure the phone is ON without a sim card in. 4) Connect the phone to the cable (ensure there is a good connection) 5) Turn Uni-Clip on using the black switch on the side of the clip 6) Press the button on the clip once 7) After a few seconds the phone will display "XXXX" on the screen, leave "XXXX" on the screen for 5 seconds then disconnect the phone from cable! (if the screen goes white with text, turn phone off by pressing the select button (top right button) on phone keypad 3 times - Then turn the phone back on to see "XXXX") 8) Enter the number 1 on the phones keypad 9) Enter 99 on the phones kepad and then press the select button (top right on phone keypad) 10) Wait for 5 seconds and press the number 3 on the phones keypad wait 5 seconds then press the select button (top right on phone keypad) wait a further 10 seconds 11) When it says "Finished please any key" turn phone off by pressing select button (top right on phone keypad) 3 times Your Phone is now unlocked for use with any sim card!!! (For handset code use same procedure, and after 99 enter 1 instead of 3. You will lose the phone book or your pictures.) SharpGx15 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Connect the USB ( gx 30) cable to Uni-Clip 3) Make sure the phone is ON without a sim card in. 4) Connect the phone to the cable (ensure there is a good connection) 5) Turn Uni-Clip on using the black switch on the side of the clip 6) Press the button on the clip once 7) After a few seconds the phone will display "XXXX" on the screen, leave "XXXX" on the screen for 5 seconds then disconnect the phone from cable! (if the screen goes white with text, turn phone off by pressing the select button (top right button) on phone keypad 3 times - Then turn the phone back on to see "XXXX") 8) Enter the number 1 on the phones keypad 9) Enter 99 on the phones keypad and then press the select button (top right on phone keypad) 10) Wait for 5 seconds and press the number 3 on the phones keypad wait 5 seconds then press the select button (top right on phone keypad) wait a further 10 seconds 11) When it says "Finished please any key" turn phone off by pressing select button (top right on phone keypad) 3 times Your Phone is now unlocked for use with any sim card!!! (For handset code use same procedure, and after 99 enter 1 instead of 3. You will lose the phone book or your pictures.) Gx10,Gx20 Instructions: 1. power on the clip 2. power on the phone 3. connect the phone to clip 4. press unlock button one time, wait until leds are solid and press second time. 5. when the leds are solid second time, remove and put back the phone battery 6.power on the phone- you can see XXXX on scren 7. press 1 ->99->top right button under screen 8. enter 3 for unlock or 1 for security code 9. press top right button again and wait until you can see the message ,,FINISHED-PLEASE ANY KEY,, for gx20 or similar for gx10.. 10. press few times top right buton to power off the phone. LG 8110 / 8120 1) Connect 4 AA Batteries to Uni-Clip 2) Connect LG cable to Uni-Clip and to the phone (phone must be off) 3) Turn Clip on. 4) For LG8110 press the unlock button once shortly and the left light will come on. 5) Now go to power the phone on 6) The Lights will flicker and then both be on constant. The phone is now unlocked. Note: For 8120 hold the unlock button down for 2 seconds and the second light will come on. Then continue as above. SENDO S200,220,300,330I,M550 1) Put 4 fully charged AA Batteries in Uni-Clip 2) Make sure the phone is off without a sim card in. 3) Connect the sendo cable to the Uni-Clip and then to the phone 4) Turn Uni-Clip on using the black switch on the side of the clip 5) Press the Uni-Clip unlock button 6) The Uni-Clips lights will turn off, 7) Press the phone power button. 8) One light will show on Uni-Clip to indicate the unlocking process has started. 9) Then both lights will be on to show the unlocking process is completed. The phones back light will go off. The phone is now unlocked. Instructions E800,E820 o Power on the clip - two led are on o Turn OFF the phone o Put NO SIM card into the phone o Press unlock button- led go off o Connect the clip to the phone - phone show <<TAT MODE>> o When two led are on and solid the phone is done Instructions E365 1. Phone off, clip on 2. Connect the phone to uniclip and press unlock button 3. Press ,, power on,, button How to activate your UNICLIP sagem calculator... 1. Connect your pc to internet 2.Uniclip OFF->connect the uniclip to pc(same like when you make update) 3. Unzip uniclip_sagem_calculator.exe and uniclip_keygen_client.exe in same directory. 4. Power on UNICLIP 5. Start sagem calculator 6.Start uniclip_ keygen_ client and select COM1 or the comport where UNICLIP is connected 7. Copy activation REQ from Sagem calculator to Uniclip_keygen_client 8. Close sagem calculator 9. Press Generate key If all is done in right order you can start sagem calculator fully activated. best regards from UNI-CLIP Team Please book mark this page as more instructions will be added as the updates come!!.. We are working on a full instruction manual and will continue to update the forum throughout the week and inform you of the latest updates. http://www.uni-clip.net/ | |
Christmas Gift From Chiragp For 10 First User Any Moto Codes | chiragsp_codes | Phone Unlocking Codes & Maps | 37 | 02-19-2008 12:34 |
LG3G eXsecute Clip unlock without test point £10 off for platinum clip user | datacablelondon | Data1 Team Products | 0 | 03-03-2006 02:25 |
LG3G series ROMANIAN LANGUAGE , FREE GIFT from me for all Romanian peoples: | Irinel | LG | 9 | 01-23-2006 23:59 |
Download link for Uni-Clip | yueyo | UNI-Clip | 2 | 10-07-2004 05:40 |
