Cables for Vpower box activated for LG Hi Mr. Vygis, I am about to buy LG Activation File for my Vpower Box, I want to know what cable I have to use to unlock new LG models, LG KG80, MG150, MG200 and, of course, new models. THANKS PD: I have Blazer box cables, can these cables work with my VPower box with LG activation? |
LG is only KG800 cable new, for all other LG you can use old cables like 7050, 81xx, or 3xx ;) You can use unlock usb, com and rj45 unibox cables, only set right com port and speed in software and all work fine ... |
Yes - VygisToolbox and Vpower use same cables like Unibox. No - You cannot use Blazer cables You have all necessary pinouts on the support areas, so you can, if you want to try, just use the connectors from the Blazer cables and build your cables for the Vpower (VygisToolbox) Or, if it is easyer for you - you can buy Unibox cables from www.tele-way.com by example. regards, Gobi |
Thanks Piotek and Gobi for answer. THANKS |
