09-08-2005, 13:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | DONGLE REPLACEMENT STARTED; discussion thread So, any Vygis software customer that have sentinel dongle (old LPT dongle or the one looking like in the picture on www.VygisToolbox.com) can ''replace'' his dongle with a new Smartcard Dongle. [glow=red]Replacement instructions for VygisToolbox from Sentinel to Schlumberger Cyberflex Smartcard Dongle[/glow] [glow=red]What is intentioned: [/glow] 1 - Saving one way delivery costs for the customers by using a logger system that creates a FIRST log from the dongle and the regfiles with the needed information. Of course some people will try to cheat- crack even this log system this make us to limit the replacement offer like this for 2 Months 2 - Making sure this reduced cost dongles will be used ONLY for replacement, and will NOT be sold to new customer by gready people. This way for our existing customer should be assured stock. Because of this, the replacement dongles, when the customer receive them, NEED TO BE ACTIVATED, by the author, using a SECOND LOG and new registration files. 3 - Keeping out the people using fake reg files, cracked vygis software, etc.. ( http://forum.gsmhosting.com/vbb/showthread.php?t=211718 ) For this, wherever a fake reg file, usage of cracked Vygis software will be detected That dongle will NOT be replaced and WILL BE DEACTIVATED. Of course also the dongles (Dongle ID’s) used in crack software are Blacklisted. (Warning for people NOT to give to anybody their reg files !!!) 4 - Customer will be able to use also the ‘’old’’ sentinel dongle, even if there will be no upgrades for this type of dongle anymore. It will still help a lot of people who have 2 shops, or 2 working places, a lot. So, actually the honest existing sentinel dongle customer will have the oportunity to get a brand new VygisToolbox Smartcard dongle for a verry low price. They will use the existing account on the www.VygisToolbox.com support site. Also, since sentinel dongles has not been shipped out anymore from the distributors since about more then 1,5 monthes anymore NEW accounts on the www.VygisToolbox.com support site will be activated ONLY for Schlumberger dongles. [glow=red]Procedure[/glow] Short description: Step 1 – Making a first log from the sentinel dongle including also the reg files and sending to the reseller. The reseller confirms if all is ok, then after receiving the payment will send the replacement dongle to the customer. Step 2 – With BOTH dongles connected (old sentinel dongle and new Smartcard dongle) you make second log file and send it together with attcahed your reg files to your reseller or directly to [email protected] Then just wait for the reg files. Limitations: You can make LOG 1 and LOG 2 file only one time with same Sentinel dongle and same PC.If you have few Sentinel dongles and want to make logs for them,you need to use other PC. [glow=red]InDetails:[/glow] - Resources: Logger software, Sentinel Dongle drivers, Smartcard Dongle drivers, and Dongle ID reader are ALL avaiable on the support website. You need just to go there and download. Please check if your drivers for the one or other dongle are installed correctly by reading the Dongle Id with the mentioned Dongle ID reader. The logs can be made for 1 dongle ONLY on one PC/dongle and 1 time. Step1: - If sentinel dongle driver is not installed on the PC, then do it now, and check by reading the ID. - Connect to PC your Sentinel dongle and start logger software. - With button "Add regs" open all reg files,which you had for Sentinel dongle. Opened reg files must appear in "Selected reg files" window. You can drag & drop reg files to this window also Check if you selected all reg files correctly,as you will can make LOG1 file only 1 times. - Fill fields "Customer info","Reseller name", "Customers main mail" and if you have second mail,please fill and "Customers second mail" field. - Press button "Make LOG1" and wait until log file will be made. If you get message like "Your dongle is dissabled"-it means,that you tried to include cloned reg files,or you have dongle with blocked ID,or you are trying to make logs using sentinel emulator.In all cases,you will not can make logs more and will not can use sentinel dongle also. First log file looks like xxxx.log1,where xxxx is your Sentinel dongle ID. Send this log file to your reseller. The Reseller confirm, then after receiving the payment will send the replacement dongle to you. Step2: - For LOG 2 making you need to have connected to your PC both dongles-Sentinel and SmartCard dongle. - Drivers for SmartCard must be installed also.If you use any software with Sclumberger e-gate card(SETools,Infinity,Cruiser, Thunderstorm or SST), then you don't need install the drivers for SmartCard dongle. Also before LOG 2 making,please check if your SmartCard dongle can be detected correctly.For checking use SmartCard ID reader,if you can read dongle ID from SmartCard dongle,you can start LOG 2 making. - Please check if you have all reg files selected in window "Selected reg files", also please check if fields with Customer,Reseller and mail info are filled. LOG 2 file can be made only one time,so all info must be correct before you make it. If everything is OK,press "Make LOG 2" and wait until LOG 2 file will be created. LOG 2 file looks like xxxx_000xxxxx.log2,where first 4 digits are Sentinel ID and next 8 digits are SmartCard dongle ID. Send LOG 2 file and ALSO all reg files atached DIRECTLY by mail to the author at [email protected] and wait for new reg files. regards, Gobi P.S. Just to make sure all people know what we are talking about: Please look at the pictures atached to identify if your USB dongle is SENTINEL or SMARTCARD DONGLE. LPT Dongles where all sentinel donlges. Last edited by Gobi; 02-26-2007 at 21:42. |
09-08-2005, 15:00 | #2 (permalink) |
Banned Join Date: Jan 2002 Location: Morocco , Tetouan
Member: 8784 Status: Offline Sonork: 100.63512 Thanks Meter: 31 | great . . But what about customer that buy this dongle from old time and reseller left this buisness ?? who can make first setup for us ? Regards . . |
09-08-2005, 15:03 | #3 (permalink) |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | but for custumer that don't have resseiler !!!! but for custumer that don't have reseeiler or can't contact resseiler (like he is in tunisie and resseiler in france) or in other country and he can't contact him whet should him do |
09-08-2005, 15:11 | #4 (permalink) | |
No Life Poster Join Date: Nov 2001 Age: 55
Member: 7363 Status: Offline Thanks Meter: 24 | Quote:
u must contact him if u're mine that welcome u havn't listen when i told u must buy from reseller like aliwali in Tunisia Last edited by aliwali; 09-08-2005 at 15:27. | |
09-08-2005, 15:19 | #5 (permalink) | |
Member: 36653 Status: Offline Thanks Meter: 336 | lol i can make this Quote:
think for you ansser | |
09-08-2005, 15:19 | #6 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Friends -- you can choose ANY reseller that is providing this replacement service. And also the resellers can provide replacement dongles for ANY customer. regards, Gobi |
09-08-2005, 15:39 | #7 (permalink) | |
show me anather reseller in tunisia u must read what Mr Gobi have shared before http://forum.gsmhosting.com/vbb/showthread.php?t=211718 u're terribel Last edited by aliwali; 09-08-2005 at 15:51. | |
09-08-2005, 15:45 | #8 (permalink) | ||
09-08-2005, 15:47 | #9 (permalink) | |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Quote:
I don't understand what you mean ... regards, Gobi | |
09-08-2005, 15:54 | #11 (permalink) | |
what i do | |
09-08-2005, 15:59 | #12 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | @ aliwali .. it has been confirmed that ali-valis mentioned dongles was actually smartcard dongles and don't need to be replaced .. @ gorgans Any reseller that want to provide this service, can provide it. regards, Gobi Last edited by Gobi; 09-08-2005 at 16:38. |
09-08-2005, 16:32 | #13 (permalink) | |
All aliwali's Vigys Custumers No need the Remplacement for your Dungle all are New card thanks (do not post dongle id number please) Last edited by aliwali; 09-08-2005 at 17:08. | |
09-08-2005, 16:54 | #15 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 49
Member: 121508 Status: Offline Thanks Meter: 1 | blank mister Gobi because of the recent problems with the police my retailer is not reperibbile thing I must make? me aids I do not know as to make in order to change to the new chiave!il my retailer it is Luigi |
BB5 Klip All Variants Discussions Thread | Cake | FuriousGold | 144 | 12-14-2007 23:20 |
V300 to V550 possible??? discussion thread | doktortelecom | Motorola P2k | 6 | 06-13-2007 06:59 |
FuriouS Online Servers DISCUSSIONS THREAD !!! | .:hack3r2k:. | FuriouS II | 275 | 10-18-2005 14:30 |
FuriouS Dongle Lite DISCUSSIONS THREAD !!! | .:hack3r2k:. | FuriouS II | 37 | 02-18-2005 14:05 |
