I unlocked a phone and now it wont power on. Hi, i just unlocked a cingular CG225. it unlocked ok and didnt have any warnings.. it said to power on the phone and enter 2945#*# but it wont power on.. the battery had 2 bars left but i dont have a charger to see if it charges. think the phone will be ok if plugged into a charger? is there any way to charge the phone with the box? |
ok so i got the charger and now it still wont power on.. what do i try? the phone worked before i unlocked it. |
check batry please or change it and read phone after post LOG here !if phone can connect to software ! |
the phone still is detected. Phone type: LG-CG225 Phone version: CG225P64FLV10c Flash type : AMD - 16 Mb IMEI : 011081-00-058616-1 Please power ON phone ------------------------------------------------ Loading boot... Boot loaded OK Flash ID : 017E2100 Flash type : AMD - 16 Mb ----------------------------------------------- Reading phone info ... OK ------------------------------------------------- when i unlocked it the battery wasnt dead, it was at 2 bars. |
Try to power on Your phone feeded from external power supply. BR Kasner |
yeah i got nothing.. when its on the charger the red light is on by the charger port. |
I uploaded at supports full flash for LG-CG225,try to write it.If still won't help-you will need to look inside phone for backup battery and disconnect it for few minutes. Regards,Vygis |
I full flashed it and it was sucessfull but it still wont power on. i dont see any backup batteries in the phone. the phone was working before i unlocked it |
Strange situation-after full flash,if hardware is ok,phone must start.One more-I need one file from this phone-after phone connecting,when software will read info from phone,press "CTRL" and "Z" on PC keyboard.Software will create file "LG-CG225_017E2100_CFI.crb"-please send it here to look. Regards,Vygis |
1 Attachment(s) here you go.. .. |
ok so i full flashed it one more time and it is turning on now. im not sure what was wrong but it looks to be ok. |
So where was problem ? :) I even uploaded at supports one more full flash for CG225 :) Regards,Vygis |
im not sure what the problem was, the other day i flashed it like 5 times and tried everything even keeping it on the charger over night. then today i just reflashed it and it turned on.. maybe defective phone. |
