LG GD510 Problem to conect via Test Point! Hi support, I try to conect the LG GD510 via Test Point but all time get this problem: Please power ON phone ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Changing baudrate ... Operation failed Or Please power ON phone ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Changing baudrate ... OK Setting bus ... Operation failed Any Ideas what can be wrong? Thanks, BR, |
press and hold power on... |
Yes i do always but same problem..... |
order lg gd510 cable from gpg and problem will be solved |
LG GD510 supports USB connection only when phone is unlocked,if phone is locked - you can only flash phone. For unlock code reading is needed to connect phone via UART using TP on PCB. |
But for me worked USB reading code as well |
how? regards Sjakie |
I have the same problem, but I use GPG g510 Cable! What is wrong? |
bro we done some off then with usb cable or with gw300 rj 45 cableots working with us 100 percent nothing happond try it and pls reply |
me too having same problem..with vygis. phone no responded error..help plz |
i have done this by connect phone via UART using TP on PCB. Phone type : LG-GD510 Phone IMEI : 357248-03-4****4-0 Please power ON phone ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Changing baudrate ... OK Setting bus ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Reading sim unlock code... OK Sim unlock code : 2605808526667336 ======== Process completed ======== Operation time - 00:01 ---------------------------------------------------------- For operation finishing,do next : - power phone ON without SIM - type 2945#*510# to enter unlock menu - enter unlock code : 2605808526667336 |
please explain what is UART . thanks |
Universal asynchronous receiver/transmitter Thats meen,you must use USB to Serial interface,any kinds,or clasic COM interface. BR. |
gw300/rj45 cable works 4 me battery out then in n power on... |
Can someone explain the procedure with the UART or the direct connection to the box, because I do not work, maybe a chart or explanation. |
