Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 08-22-2006, 17:05   #1 (permalink)
msa
Member: 17424
Thanks Meter: 15
LG KG800 restart all the time
Hi
I have LG KG800 which came to me as restarting after 'WOW' logo. I have flashed allmost all the files from support area but still same problem. Has anyone else seen this problem?, what is the cure ?.
There is no sign of water damage or any other.
Thanks
br
msa
Old 08-22-2006, 17:12   #2 (permalink)
GSM Brothers's Avatar
Member: 2203
Thanks Meter: 52
try flash full , this is problem. Full flash is 2 files not 1
Old 08-22-2006, 21:18   #3 (permalink)
msa
Member: 17424
Thanks Meter: 15
Thank for the reply.
I have flashed both files
LG-KG800_KG90P64-86-V11e-XXX-XX_EN_CH_CodeData_FW.crb
LG-KG800_KG90P64-86-V11e-XXX-XX_EN_CH_AlchemyData_FULL_#2.crb
and other versions, including a back from a working phone but it still will not power up normaly.
br
msa
Old 08-22-2006, 21:37   #4 (permalink)
Member: 4458
Thanks Meter: 25,853
At support sites exist full flash from KG800-it consists from 2 parts-full and full #2 and has IMEI number in flash name.Write both those flashes,if phone again will be restarting-make "Phone reset" from "Special" section,and if this wont help-then look your phone hardware.
Regards,Vygis
Old 08-23-2006, 02:06   #5 (permalink)
Member: 277431
I think it is hardware problem
Old 05-30-2007, 10:30   #6 (permalink)
Member: 98757
Thanks Meter: 3
i have mee to same problem in rubric fuul flash i have write full flash but stiil restartin i whant to ask is any problem that what i have change verzion or not thanks for help
Old 02-16-2008, 14:19   #7 (permalink)
Member: 289307
Thanks Meter: 44
its hardwear .but with other simcard it work normly
Old 02-16-2008, 17:40   #8 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 252
u have to change ribbon that is the problem
Old 03-08-2008, 10:28   #9 (permalink)
GEEBOO's Avatar
Member: 553840
Thanks Meter: 122
i have also in same problem set
Old 03-09-2008, 09:06   #10 (permalink)
Member: 554221
try flash full ,2 files
Old 03-09-2008, 09:15   #11 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 797
Full flash with same version,same file........
Or u can Full read from working phone then write ur restart phone
I think all 'll be ok Tested...
Old 01-28-2010, 16:52   #12 (permalink)
Member: 30709
Thanks Meter: 45
Try the battery, i had the same problem and it was a faulty/flat battery.
z140 restart all the time CLIFFORD25502 TST Dongle 3 10-13-2008 15:18
T 630 restarting all the time dashnor Sony Ericsson 1 09-24-2006 17:49
z140v restart all the time! CLIFFORD25502 QUALCOMM Models (3G) 5 07-15-2006 20:01
I'v got Restarting all the time with T610 any ideas brutalen Sony Ericsson 3 02-02-2004 00:04
T200 restarting all the time?? infogsm Sony Ericsson 1 10-24-2003 15:28
Page generated in 0.15996 seconds with 9 queries
