Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 07-20-2005, 00:38   #31 (permalink)
Member: 142001
Thanks Meter: 14
hi
thanks gobi for new update
Old 07-20-2005, 01:54   #32 (permalink)
kaaniletisim's Avatar
Member: 79065
Sonork: 100.1646746
Thanks Meter: 78
Good upgrade thnx vygis team
Old 07-20-2005, 08:16   #33 (permalink)
Tinotenda's Avatar
Member: 46546
Sonork: 100.1577435
Thanks Meter: 85
great update, keep it up Vygis...
Old 07-21-2005, 10:51   #34 (permalink)
Member: 13122
Phone type: MicroSnapper
Phone version: KM67 -T-M001-ISC-4MROM-xx-20040819A
Phone IMEI : 352192-00-XXXXXX-5
Please power ON phone and keep ON button pressed,until boot will be loaded.
Loading boot...
Loaded OK,release ON button
Reading flash ID...
Flash ID : 047E0201
Flash type : Fujitsu - 8 Mb
Readed OK
Reading phone info ... OK
Unlocking... OK
====== Process completed ======
Operation time - 00:01
phone unlocked ok
Old 07-21-2005, 11:19   #35 (permalink)
hema's Avatar
Member: 19267
Thanks Meter: 100
@ headmaster
how did u do it , did u soldered the cables directly or by a connector ( which connector)
regards
Old 07-21-2005, 12:56   #36 (permalink)
Member: 13122
Open phone and solder wire
it take about 5mn and easy to do
Old 07-21-2005, 18:44   #37 (permalink)
Member: 143848
Thanks Meter: 105
just did one with Vygis and it really worked cool .. thnx vygis team
Old 07-22-2005, 07:21   #38 (permalink)
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Thanks Meter: 93
Nice Update This Is Really Good
Old 07-23-2005, 11:04   #39 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Thanks Meter: 1,654
wow!!! really thanks vygis team, the gift comes in the right time, i unlocked 2 phones untill now
21/07/2005 19:06:29 ************************************************** ***************
Phone type : MicroSnapper IMEI : 352192-00-XXXXXX-9 Operation type : Unlock
22/07/2005 18:22:16 ************************************************** ***************
Phone type : MicroSnapper IMEI : 352192-00-XXXXXX-1 Operation type : Unlock
Old 07-26-2005, 09:47   #40 (permalink)
Member: 8843
Thanks Meter: 117
@ Gobi and ALL
i tried the following connectors and all failed: sgh600 (not that bad), lg81xx etc etc
use XDA CONNECTOR works 1000% without cutting any pieces
this is the pin out:
Snapper pins..................XDA CONNECTOR.........VYGIS/ WHITE BOX color
GND 1-----------------------1----------------------------Green & Orange
TX 11----------------------13----------------------------White
Rx 12----------------------15----------------------------Red
Keep up the great work Gobi i unlocked mine.
Old 07-26-2005, 10:02   #41 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,594
Thx for your Tip.
I will put your post also in Tips&Tricks section
Suggestion: Because chinese cable factories don't use on all lots same coloured wires for Rx, Tx, Gnd line --> guide yourself better on the pinout marked on the box, instead on that colours.
All credit for the super updates goes to the author, mister Vygis.
regards,
Gobi
Old 07-29-2005, 11:57   #42 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Originally Posted by datalife2000
@ Gobi and ALL
Is the XDA connector an 18 pin or 24 pin as Ive just bought one to make cable and its 24 pin also do you mean to solder wires on to pins 1 , 13 , and 15 of XDA connector so they line up with the snapper pins?
Old 07-30-2005, 13:33   #43 (permalink)
lemor's Avatar
Member: 38562
Thanks Meter: 1,478
@ Gobi and ALL
i test this solution...the problem is RX is not connected or detected...
much better to use the original USB cable of this phone...just get the head of the cable and resoldered the wires..... i tested it a while ago...and it works...i already tested the flashing, writing eeprom and unlocking it works like a charm...
thanks to vygis team
br
lemor
Old 07-30-2005, 13:36   #44 (permalink)
Member: 55062
Thanks Meter: 7
some one must be making leads for this phone?
Old 07-30-2005, 16:01   #45 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
br
lemor
Where did you get original usb cable for this phone? I phoned up virgin mobile and they tell me they discontinued the Micro snapper and when I enquired about cable to connect to pc they told me there wasnt one. It didnt come with one and theyve never had a cable to connect to a pc
New Links for now BlackBerry Unlock Software (MFI Loader and Files) iceman_27 BlackBerry (RIM) 26 09-26-2011 10:03
V3R new v3.. can't flash and unlock? anyone know how? davidliu21 Motorola P2k 5 04-07-2006 16:06
whish software to flash and unlock a nec n710 ?? humbedj NEC 1 01-26-2006 06:56
Wanted: New BenQ Flashing and Unlocking Software PolyRing Wanted Products 1 11-03-2004 23:05
New TELIT phones ? Flash and unlock software? legija Various 0 12-22-2003 23:31
Page generated in 0.43438 seconds with 9 queries
